Mechanics - What Is This? Does It Get Hot?
Old Aug 7, 2015 | 11:20 AM
shift's Avatar
Default Mechanics - What Is This? Does It Get Hot?
This piece of the exhaust system on my car has a barcode/sticker on it (not sure why). It's stuck on really good, so I might use some potentially flammable adhesive remover to get it off cleanly. I don't think it gets hot since the barcode/sticker doesn't look like it's heat damaged, but I want to make sure. Don't want my car to catch on fire
Old Aug 7, 2015 | 11:48 AM
McGriddle's Avatar
I'm no mechanic, but I believe that's the actual bottom of the exhaust muffler/silencer housing and not a separate skid plate or cover. Thus, it does get hot! How hot I'm not sure, but maybe best not to use something that can leave a flammable residue on it?
Old Aug 7, 2015 | 12:08 PM
buickfunnycar.com's Avatar
So...you wrapped your car red?
Old Aug 7, 2015 | 12:40 PM
shift's Avatar
photo isn't my car, just image I found on Google. It appears the sticker must be a JLR part # or something...
Old Aug 7, 2015 | 12:44 PM
shift's Avatar
The annoying thing is when I try to take a low level photo the sticker is visible!
Old Aug 7, 2015 | 01:53 PM
I was just joking on the red part but yes,I have noticed that sticker on mine too and it bothers me as well.
Old Aug 7, 2015 | 03:01 PM
shift's Avatar
So I'm not the only one then. It's just so cheap looking when you are admiring that *** to see this price sticker thingy.
Old Aug 7, 2015 | 03:18 PM
Unhingd's Avatar
Use the solvent of your choice while the muffler is cold. Wipe off the residue when done. Any residual amount will safely evaporate off as the muffler warms up. When in motion the minuscule amount of vapor can't maintain an air/fuel ratio within the range that is combustible.
Old Aug 7, 2015 | 05:52 PM
99Gsp's Avatar
Snap, crackle, pop and flame coming from the rear....you will definitely draw the crowds of onlookers!! :-)
I'm going to look for that sticker too. I have a label indicating the windshield mfg date still adhering that I need to remove. Guess I need to 5S my car to use a Lean expression.
Old Aug 7, 2015 | 06:22 PM
IronMike's Avatar
Seen the sticker you are referring to on every F-Type. Very noticeable from directly behind the vehicle, especially when you might crouch for a low camera angle, as well as from any car that might be following you.
I removed mine within days of delivery. Drove me nuts. Any decent adhesive remover when the car is still cold will do the trick.
Old Aug 8, 2015 | 04:29 AM
F-typical's Avatar
I'm guessing this is a V8 only problem?
Old Aug 8, 2015 | 04:55 AM
AnD3rew's Avatar
Yes tried to see today in my V6, but the pipes are in the way so without lying in the ground you can't really see.
Old Aug 8, 2015 | 06:22 AM
DuhCar's Avatar
Another first world problem.......
Old Aug 8, 2015 | 08:45 AM
Foosh's Avatar
LOL . . . that's usually a pandemic on all internet car forums.
Old Aug 8, 2015 | 01:46 PM
bjg625's Avatar
Calling Dr. Freud!
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Nov 13, 2022 02:55 AM
Blaine Trarop
Sep 23, 2015 03:08 PM
chatmanx
Sep 11, 2015 07:17 PM
explorer364
Sep 11, 2015 05:44 PM
