Mina Gallery intake kit
Old Mar 31, 2021 | 02:29 PM
  #241
lpf4's Avatar
Just read through this thread, and saw a few people asking about better cone filters. I just got my intake kit in today, and measured the filters as best I can:
3.5" Inlet ID
1.5-1.75" Inlet Length
19" Base Circumference = 6" base diameter
4 7/8 to 5" Top
7 1/4" filter height from base to top
8.75" over-all height
Injen makes a dry filter (Super NanoWeb) that gets phenomenal filtration efficiency for a cone filter, and it's re-branded by Amsoil (a little extra name-drop doesn't hurt, being Amsoil and all), and is -significantly- better than the Injen 8-ply oiled gauze filters, which are themselves better than the 6-ply oiled gauze that Mina ships. I ran the measurements through the Injen site and found this filter:
X-1021-BB
3.5" Inlet ID
1.75" Inlet Length
6" Base Diameter
5.35" Top
6.875" filter height from base to top
8.375" overall height
So it's a little wider at the top (a bit under 1/2" wider), but is also about 1/2" shorter overall, which should fit well in the space and might even provide more clearance considering the Mina filters seem to hit the bumper on some installs. All other dimensions are the same. It also has a concave velocity-stack type tip that is most likely a gimmick, but is supposed to help start a vortex under throttle. I bought a couple - Amazon has them in stock on prime (only 6 left now) with fast shipping. You can also get their Injen X-1037RED or X-1037BLK HydroShield dry socks, which are made to fit that filter.
Old Mar 31, 2021 | 05:23 PM
  #242
Josiah21's Avatar
3.5" Inlet ID
4 7/8 to 5" Top
X-1021-BB
3.5" Inlet ID
1.75" Inlet Length
6" Base Diameter
5.35" Top
Thanks for the info just placed my order as well for filters and socks!
Old Mar 31, 2021 | 08:15 PM
  #243
Whatsnext's Avatar
I placed an order as well. That part listed above should correspond to this link, but the dims seem a bit different from what is listed above.
Amazon Amazon
Old Mar 31, 2021 | 08:26 PM
  #244
Josiah21's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
yea some of the dimensions listed for that on Amazon are not correct. they typed the information on it wrong, but that same item number on the Injen website shows the dimensions are correct to what is close enough to what we need. I ordered mine using that part number right from their site directly. i was not worried about getting it anytime soon since the intakes are already installed on the car. Just be sure to measure it when you get yours to make sure Amazon didn't mess it up.
Old Apr 2, 2021 | 01:16 PM
  #245
lpf4's Avatar
Yup, whoever made the listing must have copy/pasted, because the 'wrong dimensions' are the same dimensions they use in all of their listings for Injen Nanoweb filters, regardless of P/N. The title gave the correct P/N and the correct inlet flange ID per Injen's specs sheets, so I gave it a shot. I'll validate the P/N and sizing when it comes in on Sunday, but it's Prime, so I can just send 'em back and buy it off Injen if it they don't send the right part.
Old Apr 4, 2021 | 04:26 PM
  #246
lpf4's Avatar
Got the Injen / Amsoil X-1021-BB filters and X-1037BLK pre-filters in today, and they look like they'll be a good match. Inlet ID and base diameter look identical, and height/top width look close enough that it should fit fine. Might even be an easier fit, being a half inch or so shorter. Left is Injen X-1021-BB, right is private label from Mina.
Plus the Injen filters are made in the USA, not sure where the private label Mina filters are made, but being generic 6-ply wet filters, could be anywhere.
Old Apr 4, 2021 | 05:37 PM
  #247
Whatsnext's Avatar
lfp4
Let me know how your install goes. I haven't installed mine yet and still debating best way to access the OEM filter boxes-fender well or underneath. And I think I may buy the sock filters as well. Not sure I need it as I live in the desert but could be helpful.
Old Apr 4, 2021 | 09:36 PM
  #248
lpf4's Avatar
lfp4
I'm not in a huge rush either, but I'm planning on pulling the whole bumper for something else, and it should give me really good access to everything.
Old Apr 14, 2021 | 10:07 AM
  #249
EH786's Avatar
Mate - love the deep black gloss look you got going on - seriously mean! Happy for you
Old Apr 14, 2021 | 01:13 PM
  #250
Guardian's Avatar
Just finished installing mine and one thing I would like to share with you guys: unless I made something incorrect (which I doubt), if you have SVR bumper you won't be able to use provided by Mina brackets (design to hold bottom section). Instead I have used few zip ties which worked fine too.
@Biofreak - have you experienced same thing?
Old Apr 14, 2021 | 09:05 PM
  #251
Whatsnext's Avatar
Did you just remove the fender lining to gain the airbox area? I am planning on installing mine this weekend.
Old Apr 15, 2021 | 04:37 AM
  #252
Guardian's Avatar
I did everything during SVR body kit conversion while the bumper was off.
Old Apr 15, 2021 | 06:11 AM
  #253
Unhingd's Avatar
Working on it with fender lining removed gives far easier access to all the connections to allow proper alignment than doing it from underneath. Removing wheel and fender lining takes no more than just a few minutes.
Old Apr 15, 2021 | 02:57 PM
  #254
CapnToll's Avatar
Just found this thread - I think I'll give this a go on my F-Pace SVR! Or...when my facelift SVR arrives. Start with just the top section and see how it sounds.
Old Apr 15, 2021 | 04:03 PM
  #255
Guardian's Avatar
Top section will not "open up" supercharger whine as replacing of OEM filter boxes does.
IMO intake with just top section doesn't make sense.
Old Apr 16, 2021 | 06:03 AM
  #256
Unhingd's Avatar
Agreed. I added the top section first. No appreciable difference in SC whine. The muffling baffles are eliminated with the installation of the lower section. HUGE increase in SC whine.
Old Apr 16, 2021 | 01:40 PM
  #257
CapnToll's Avatar
Mmm...well I think with the F-Pace I need to do top and bottom sections anyways for fitment. The F-Pace SVR has a single piece top section and different air boxes than the F-Type R so I can't be sure the Mina top section would reach the F-Pace air boxes. The full top/bottom set should be fine since it would replace everything assuming there's as much room or more inside the F-Pace's engine bay and clear the fender indents.
Old Apr 16, 2021 | 06:59 PM
  #258
Sparky H's Avatar
Default Unhingdster Tech Advice Please!!!
Too lazy to search....Friday ya know!! 2017 F Type V6S: Can Mina Lower be installed to stock Upper?
Thanks in advance Sir
Old Apr 16, 2021 | 08:43 PM
  #259
Sparky H's Avatar
for the supercharger whine only??
Old Apr 16, 2021 | 08:54 PM
  #260
OzXFR's Avatar
I will assume the Unhingd mantle for a moment.
Yes, the Mina upper and lower intake kits can be installed separately or together, which means the lower can be fitted to the stock upper.
Well that's what the Mina web site is implying as they advertise them separately and as a kit with both, see here: https://www.minagallery.com/f-type-performance-items/
