Mina Gallery intake kit
Old Jul 24, 2019 | 03:15 PM
  #81
Unhingd's Avatar
Originally Posted by ntbrinkl
I haven't been on here in a couple months and come back to check in on an air intake and find this! Lucky timing.
So Unhinged what air filters are you running? I looked over all the post and didn't see anything about that.
Also are you getting Stuart to adjust your tune?
Check the pics above. Only the tubing is being replaced. Aesthetic mod only. Unlikely to produce additional airflow. No need to adjust the tune.
Old Jul 29, 2019 | 05:12 PM
  #82
Timbo's Avatar
You've left the sound inhibitors on the intake so you wont hear that much more sc whine.
I have the gt4 kit and hear bugger all lol but thats because i have 200 cell cats and velocity back box which as you all know is bloody loud.
Old Jul 29, 2019 | 05:25 PM
  #83
Terrance39's Avatar
I made my own intake with all sound tubes deleted, and the whine is glorious lol.
Old Jul 29, 2019 | 05:51 PM
  #84
Luc Lapierre's Avatar
Looks like you've got a cover over top of the intercooler?
What's the material?
Old Jul 29, 2019 | 05:54 PM
  #85
Terrance39's Avatar
I had the lid powdercoated.
Old Jul 30, 2019 | 01:20 PM
  #86
KVO's Avatar
KVO
What parts did you use for the sound tube delete - I'd in particular would like to know the diameters of both airbox and original top tube connection.
Old Jul 30, 2019 | 01:23 PM
  #87
Terrance39's Avatar
3.25"
Old Sep 5, 2019 | 08:26 PM
  #88
OzXFR's Avatar
Lance (and anyone else who has fitted the Mina intake kit to a V6).
Can you report back on any noise changes - SC whine, intake roar, exhaust note etc etc.
Also any change to power/torque/performance although I understand there is either none or so little as to be undetectable.
I'm still tossing up whether to get one of these kits but if they are purely for appearance/aesthetics then maybe not.
Old Sep 6, 2019 | 04:02 AM
  #89
Unhingd's Avatar
Appearance is the only perceived benefit. (Worth it to me).
1. Even if it adds a few horses, at 450hp you won’t notice it, and too expensive to put on the dyno to prove something you can’t feel.
2. Only the plastic cross tubing and down-elbows are replaced (with polished aluminum). The filter boxes and the mufflers just above the boxes are left in place, so there is no increase in whine or intake roar that I can detect. That doesn’t mean that it doesn’t exist. The sound from the VAP exhaust under full throttle would drown out the sound of a jet engine.
I would like to replace the intake mufflers with straight pipe. I am certain that would produce the desired sound.
Old Sep 6, 2019 | 09:47 AM
  #90
Tel's Avatar
Tel
I like your solution alot.
Did you weld any tabs on to support the tubes (I cant see any weld/witness marks) as on the OEM setup? - reason I ask is that I use cone filters after the MAF and need a system that is supported up top as in the OEM design. Mina at present doesn't support its' tubing system at all, and relies as I think you have, on the lower brackets and MAF supports into the OEM airboxes to keep it all rigid.
Old Apr 14, 2020 | 09:12 AM
  #91
Row_ca's Avatar
Reviving an old thread as opposed to starting a new one... wondering if the Mina Gallery Upper Intake Kit could be combined with the YW MotorSports Lower Intake Kit (https://www.ywmotorsports.com/produc...-lower-intake) to effectively make a full intake set-up at around $575? Seems less cost prohibitive than the competitors but not sure if it's feasible.
Old Jun 26, 2020 | 12:57 PM
  #92
Therock88's Avatar
I will let you know soon. And I sure hope so....I already have the YW Intake (Lower) and just ordered the Mina Gallery upper Intake....From what I can see above, it should fit, as the YW picks up right where the Baffle sits, and these appear to end there?
I will post info when I get it installed.
Also...Thanks UNHINGD for all of the pictures and Install tips! That will be helpful to have when it gets here.
DC
Old Jun 27, 2020 | 06:21 AM
  #93
bcbruno's Avatar
Is any option in carbon fiber like eventuri but the upper part?
Something like this?
Old Jun 27, 2020 | 06:52 AM
  #94
JacksonvilleJag's Avatar
I wish Yellow Wolf was still around. Anyone know of any other options for the lower other than Eventuri?
Old Jun 27, 2020 | 09:54 AM
  #95
Therock88's Avatar
I had no idea they were not still around. Man, it would be so easy to fabricate what they produced. I am not a fabricator, but it is nothing special. Seems like with a few measurements it could be reproduced. Only pieces that would require any fab would be the bracket, and bending the tubing I think?
See below...
DC
Old Jun 27, 2020 | 09:55 AM
  #96
Therock88's Avatar
That thing looks Purdy!
DC
Old Jun 27, 2020 | 10:16 AM
  #97
madmax1911's Avatar
wow, who makes that ?
Old Jun 27, 2020 | 12:10 PM
  #98
bcbruno's Avatar
Is just an idea for a 3d printed mold.. i would rather buy one.
Old Jun 28, 2020 | 09:21 AM
  #99
madmax1911's Avatar
Well if you decide to build some and could do it at a reasonable cost, I bet they would sell like hot cakes on here.
Old Jun 28, 2020 | 01:49 PM
  #100
bcbruno's Avatar
If i do it i will give diy data
