Mina Gallery intake kit
Old Sep 21, 2020 | 11:31 AM
  #121
Therock88's Avatar
Originally Posted by Unhingd
Changing the pulley(s) will not increase the whine very much. The big increase in whine should come from replacing the baffled section of the intake with a straight metal tube. That tube is available with the Mina lower intake kit. That kit comes with an oil filter that probably does not capture as much particulate matter(dust) as a standard paper filter. Perhaps the baffled section can be replaced while keeping the OEM filter box in place. I’m going to try to get to this project this week.
Agree 100% with Unhingd. This is your problem! I have upper and lower intake upgrades, and you can hear the whine until the exhaust kicks in! No issues with a cone filter with the waterproof mesh cover. Based on location and no real openings, should be OK.
Good luck
DC
Old Sep 21, 2020 | 06:41 PM
  #122
Unhingd's Avatar
Originally Posted by WayneB
Have you looked at Amzoil filters?
They come in all assortment of sizes and fitments.
I put one on my BMW M Roadster when I found the ITG foam oiled filter on the cold air intake starting to disintegrate.
Thanks for the suggestion.
Old Sep 22, 2020 | 08:05 PM
  #123
TAEUCK Goo's Avatar
Is here any way to use OEM filter box with mina upper intake tube?
only change the section(s/c pacifier)to increase whine?
Old Sep 22, 2020 | 08:40 PM
  #124
Therock88's Avatar
No...The Baffle is part of the lower intake. You can use the Mina upper with the OEM lower, but that still leaves the baffle/pacifier in there. The most sound comes from removing the lower baffle (part of the lower intake) as shown.
It may be possible to leave the OEM AirBox and just use the piping from an aftermarket lower intake...But you would need to line it all up properly, and hope it is the right length (and I do not think it is?).
DC
Old Sep 23, 2020 | 06:45 PM
  #125
TAEUCK Goo's Avatar
Thanks for the advice.
Then, there is 2 ways for me to make the s/c whine louder.
one is to use open filter that will come up with the tubes replacing paficier.
second is to use aftermarket lower intake with oem filter. Do you happen to know where to buy?
What do you mean by line it all up properly? if lower tube is sold, it is already being set to be used right ? No?
Old Sep 23, 2020 | 07:32 PM
  #126
Therock88's Avatar
What I mean, is the lower Intake kits are designed to replace the whole lower unit, including the airbox/filter. If you just want to use the "Tube" portion (to get rid of the baffle/silencer), you will need to be sure it lines up/aligns/fits into the factory AirBox. MAy require some alteration? I think Unhingd is considering doing something like that from a previous post?
So you would have to mate up the new pipe and original box like I tried to demonstrate below quickly in Photoshop....my worst work ever, but you get the point. Have to be sure the red circle area would mate up...
DC
Old Sep 24, 2020 | 12:27 AM
  #127
TAEUCK Goo's Avatar
Thanks for the kind information.
Now I get it.
Lower intake means open filter maybe. which Unhingd doen't recommend to use because of several reasons.
To use Oem filterbox i need to kinda tubes to replace pacifier only and that kinda thing isn't being sold at the moment in the market.
Right?
Old Sep 25, 2020 | 03:59 PM
  #128
Unhingd's Avatar
I’ll get on this hopefully this weekend. I think the best solution will be to use the Mina lower tubing, and find a cone filter with a properly filtering paper/fabric element.
Old Sep 26, 2020 | 11:02 AM
  #129
WayneB's Avatar
Try looking in here https://www.amsoil.com/p/eaau I think you'll find what you're looking for. They're really nice filters and you can find one to fit almost any where.
Old Sep 26, 2020 | 08:35 PM
  #130
TAEUCK Goo's Avatar
you mean to use mina open filter connected to upper mina intake and cover the filter with the proper one, do I understand well?
Old Sep 27, 2020 | 07:35 AM
  #131
Unhingd's Avatar
No...I want to use just the Mina lower tubing with the upper Mina intake already installed, and find a paper filter to use rather than the oil soaked filter provided by Mina. Oil soaked filters do not filter as well as the paper media filters. I don't want to sacrifice engine longevity for sound,. Performance is minimally affected by filter type.
Old Sep 27, 2020 | 06:43 PM
  #132
TAEUCK Goo's Avatar
Does Mina offer only lower tube w/o filters?
I never find the one on their site.
Or you purchase lower section inc.filter and just leave aside the filter and use another filter w/o oil soaked?
If this is right, what filter are you suggesting?
Old Sep 28, 2020 | 02:07 AM
  #133
JacksonvilleJag's Avatar
How far off is it to modify the Mina lower tubes to use with the OEM filter boxes?
Old Sep 28, 2020 | 05:33 AM
  #134
Unhingd's Avatar
The Mina lower intake comes with oil soaked filter cones.
I will be checking that out when I get to this installation.
Old Sep 29, 2020 | 07:06 PM
  #135
Unhingd's Avatar
At least on the left side of the car, the OEM filter box can be left in place with the Mina lower intake:
Old Sep 30, 2020 | 09:42 AM
  #136
madmax1911's Avatar
Fingers crossed the other side is the same 🤞
Old Sep 30, 2020 | 09:45 AM
  #137
Unhingd's Avatar
I’ll work on that today.
Old Oct 4, 2020 | 07:53 PM
  #138
TAEUCK Goo's Avatar
Have you done successfully? for both side?
Doesn't it show any error code when removing pacifier?
So, I need you purchase mina lower tube package and the open filter included is useless when I want to keep oem filter box.
Right?
Old Oct 4, 2020 | 08:21 PM
  #139
Unhingd's Avatar
Right?
I’ve been tied up playing on the the John Deere doing some erosion control on the stream, so no progress on installing the lower intake on the right side. Maybe tomorrow.
No error code with the left intake replacement. The OEM MAF tube section is used with the Mina lower intake on that side, so I would not expect a code to be thrown.
Yes, I did not install the cone filter provided by MINA.
With just the left side installed, I still don’t hear much more SC whine. The cone filters may be needed to get the SC whine.
Old Oct 4, 2020 | 08:36 PM
  #140
TAEUCK Goo's Avatar
Thank you soooo much for the kind reply man!
So...
Even if I replace OEM pacifier with the tube offered by Mina , it doesn't really bring dramatic change on S/C whine.
Should change oem filter with cone filter that will increase the sound of S/C.
As I ordered and changed upper intake expecting only S/C whine , I don't really want to do uncertain job.
Your job is really helpful for me in this regard.
Conclusion is..
Even if pacifier is replaced with lower mina tube, it won't give an effect on s/c whine.
Hm..
Don't know now how to do for my goal to hear S/C shine.
