missing yellow lines rear view camera
Old Mar 24, 2025 | 01:01 PM
Hillbert's Avatar
Default missing yellow lines rear view camera
Hello Jag fans,
Recently I have had installed a new (second hand) rear view camera to my MY 15 F-type coupe. The lens of the previous really was deterioating. The view of the new one I bought from Ebay is far form perfect but gives a bit a more detailed view. However, the yellow lines are missing. And I'dont want to damage my refurbished 20 inch Tornado rims. Any suggestions please?
Greetings from The Netherlands
Hillbert
Old Mar 24, 2025 | 06:40 PM
Carbuff2's Avatar
Can't help with the lines on the screen,
But do you have your outside rearview mirrors set to tilt down a usable amount when backing?
Frankly, I use that more than the screen. My only problem is, sometimes I go too fast on my longish driveway in reverse, and they stop tilting...
Old Mar 26, 2025 | 03:34 AM
Hillbert's Avatar
Hi Atwell, thank you for your suggestion and yes, I calibrated the tiltdown function on the mirror. But still very eager to hear other feedback!
Old Mar 26, 2025 | 07:48 AM
Borbor's Avatar
Reversing lines are a software overlay over the camera feed. Only thing I can think of is battery disconnect and leave for at least 15 mins so any residual current in the relevant module can discharge. Don’t close the boot whatever you do so you wont be locked out. Fingers crossed for you
Old Apr 22, 2025 | 01:11 PM
Hillbert's Avatar
Disconnecting the battery didn’t do the trick other suggestions welcome!
Old Apr 22, 2025 | 06:19 PM
Valerie Stabenow's Avatar
Default Possible help
I couldn't find help in my online f type docs, but found camera line setting info here:
https://www.fpaceforum.com/threads/b...e-lines.12698/
Old Apr 22, 2025 | 11:29 PM
Hillbert's Avatar
I’ll check it out. Thanks Valerie
Old Apr 23, 2025 | 11:00 AM
Hillbert's Avatar
Valerie is right: it’s just a settings issue in the main screen menu (so not the steering wheel menu so to speak). It takes an expert to see the obvious
Thanks again Valerie.
Old Apr 23, 2025 | 08:25 PM
You are so welcome! Hope it all works like it should!
Colin Chapman
E-Pace
Oct 19, 2023 02:12 AM
Ohwams
Sep 1, 2021 03:59 PM
Bob Hornby
Apr 18, 2021 06:27 AM
STMPY
Oct 3, 2019 02:25 PM
