Module flashing / programming communications failure
Old Dec 13, 2021 | 03:59 PM
Necromant1k's Avatar
Default Module flashing / programming communications failure
Hi!
Tried recently to update IPMB (Image processing module B), but run into an issue:
The following modules failed download
Image Processing Module "B"
A failure occurred - Error code A01 Communications failure
I've been trying multiple times and it always failing with the same issue.
I see that block/module functional and has no any DTC yet.
Due to that i've lost access to reverse camera (Camera system fault)
Any ideas what can be wrong? What can i do in order to resolve this issue?
Can it be related to equipment i use (was able to update PAM without any issues)?
Equipment i use:
  1. VCX SE
  2. SDD 160.3
Old Dec 15, 2021 | 02:28 AM
Old Dec 15, 2021 | 06:49 AM
Therock88's Avatar
Not sure any/many can help here. Couple of observations...
Appears your application is displaying something like Russian?
Also from your screens - Your car (or the car listed on the screen) is an XF(X260) not an F-Type, so maybe that forum can help you? This is a F-Type (X152) forum
If you are using "Cloned" software/hardware, that could certainly be an issue with not being able to access all modules and/or program them. Some clones are better than others.
Last...At a point in time JLR started using VCI/IDS and if you have a newer (I think 2018 on) car, some SDD version is likely not going to work, or work fully.
That's all I have...
DC
Old Dec 15, 2021 | 06:57 AM
Last...At a point in time JLR started using VCI/IDS and if you have a newer (I think 2018 on) car, SDD is likely not going to work, or work fully.
DC
Makes sense
Yeah, seems like i've created a thread somehow in wrong directory.
1) Yeah in Russian since i'm from Belarus. Just changed language in order to show an error
2) I have 2016 MY car, so i think SDD should be good, but i'll try different SDD version
Anyways, thank you for response
Old Jun 27, 2024 | 07:16 PM
Rbrites's Avatar
Did you fix it?
Old Nov 1, 2025 | 05:02 AM
scg661's Avatar
Also keen to know if you got a fix as having the exact same issue.
Old Nov 1, 2025 | 10:28 AM
uh, unfortunately camera after this was completely cooked so I had to get brand new and started to work
Old Nov 2, 2025 | 11:28 AM
scg661's Avatar
Ah! Not ideal. Mine is still working for sign recognition, so hoping its something else!
panthera999
General Tech Help
Sep 5, 2024 02:01 PM
Speedmaster
Jun 10, 2021 10:32 AM
Ken from down under
XJ40 ( XJ81 )
Jul 15, 2020 04:10 PM
Ray Ray
Dec 24, 2019 03:24 AM
magmedia
May 19, 2015 04:58 PM
