new owner - 2 questions
Old Feb 28, 2022 | 08:52 AM
stirlingsilver's Avatar
Default new owner - 2 questions
1. I’d like to see my engine ;-). How does one remove the engine cover, just lift it straight off? This will not fire off any codes, I hope.
2. What is the correct wheel nut torque?
Old Feb 28, 2022 | 09:38 AM
Dwight Frye's Avatar
The engine cover is just a friction fit over 4 lugs on the top of the supercharger cover. Pull it straight up and it will come off easily.
The correct torque for the wheel lug nuts is 92 ft/lbs if you are using a torque wrench graduated in ft/lbs, or 125 Nm if graduated in that method of measurement.
Old Feb 28, 2022 | 11:25 AM
eeeeek's Avatar
FYI - the engine really isn't much to look at. I was disappointed when I pulled off my cover. I believe unhinged had his intake manifold polished, which helped, but it still is a design with no regard to aesthetics. It's a far cry from the beautiful old DOHC straight six.
Old Mar 1, 2022 | 06:46 AM
Mark7Seven's Avatar
I forget how “ugly” the power plant is when I put my foot down on the right pedal and feel the power while hearing the sexy sounds this car makes.
Old Mar 1, 2022 | 08:48 AM
YRS's Avatar
YRS
I wouldn't go as far as to call it ugly though. With the cover off and the supercharger standing proud I think it looks both mechanical and genuine. I can't abide a bunch of wires, hoses, and clamps on top of the motor. Frankly, high end Italians aside, the American's are killing it in this area.
Old Mar 1, 2022 | 08:59 AM
KalamazooJag's Avatar
I have purposely never removed the engine cover...I like to keep the mystery alive.
Old Mar 1, 2022 | 09:01 AM
Therock88's Avatar
I can save you some time...Here is my R with WMI with cover removed (permanently!). Nothing much to look at...Mine does have the spray nozzles for the WMI and a Mina Intake...
DC
Engine cover removed
And...A step further with the intake lid removed too!
Old Mar 1, 2022 | 09:15 AM
Precisely why I never removed the engine cover...
Old Mar 1, 2022 | 09:20 AM
Therock88's Avatar
Definitely not worth removing for "Looks". It is for cooling. Jaguar even removed the OEM cover for SVRs that have a modest 25 bhp bump. The cover just retains all of the heat, so it is worth removing for better airflow/cooling. Even the newer engine covers are smaller and have many more openings than older ones...Again, to dissipate heat.
Just FYI.
DC
Old Mar 2, 2022 | 09:49 AM
I have toyed with the idea of using a fine tooth jigsaw blade to cut out the panels on my engine cover along the lines in the photo below. And then maybe painting the cover red with some appropriate paint for the plastic material. It would let out some of the heat. But then again what would show under the cut outs isn't all that interesting. And I imagine to replace that engine cover would not be cheap if I messed it up or decided I didn't like it. It might have looked good if Jaguar had done it and maybe put some kind of mesh inserts in the cut outs.
Old Mar 2, 2022 | 10:10 AM
Folks,
Here are 3 pics of the F-Type P300 turbo 4-cylinder top cover, top cover removed and secondary cover removed. Indeed, the top cover is simply held with 4 nylon ball-n-socket fasteners.
It is certainly not as glorious looking as a detailed XK straight 6, or a classic V-12, but that's okay. I feel better now that I can see more of the mill, and am getting familiar with my new Jaguar.
Top cover, 4-cylinder
second cover, in place
third cover, in place
Old Mar 2, 2022 | 11:48 AM
SassySarah's Avatar
Some things are better left unseen.
Old Mar 2, 2022 | 01:02 PM
Phantomf4collector's Avatar
I absolutely love my 2016 F Type R, but Jaguar dropped the ball when they designed the overall look under the hood compared to so many other manufacturers.
The supercharged Corvette and Hemi engines from Chrysler are examples.
The pictures of 3 covers over the 4 cylinder version looks even less attractive than the V6 and V8.
I also own an S2000 and the engine looks beautiful when you open up the hood.
Old Mar 2, 2022 | 01:29 PM
eeeeek's Avatar
This was good looking....
Old Mar 3, 2022 | 02:24 AM
GeorgeIII's Avatar
Of course you can also do this.......
Of course you can always do this.....
Old Mar 3, 2022 | 09:05 AM
While I totally appreciate the amount of horsepower generated by the supercharger and the lack of constant tuning and maintenance afforded by modern fuel injection systems, it sure would be glorious to open the hood and see eight Webers with velocity stacks wouldn't it ?
Old Mar 3, 2022 | 09:13 AM
DJS's Avatar
DJS
You'd need a hood like this, with the window removed.
Old Mar 12, 2022 | 06:17 AM
takeapieandrun's Avatar
Fabricating a glass window in the hood only to display the engine cover is an odd choice in my opinion.
I must be the only one who thinks the AJ engine is decent looking. I used to have a G35 that was much uglier; painted the cover and put it back on in that case.
Old Mar 12, 2022 | 09:03 AM
Carbuff2's Avatar
Even lowly lawn mower engines have engine covers these days.
Emil Taraba
Aug 18, 2020 09:36 AM
chrisleg
Jan 3, 2019 04:32 AM
ioneabee
Oct 12, 2016 12:21 PM
powerhouse
Dec 6, 2014 12:14 PM
jagpro69
Dec 1, 2010 02:23 PM
