new seats in older car
Old Nov 11, 2023 | 10:09 AM
c131frdave's Avatar
Default new seats in older car
I have a '16 R, and I'm really struggling with the seat position. I am 6' 1" tall and have a back condition that causes the upper part of my spine to curve outward slightly. It's not quite a "hump back", so to speak, but I have to recline seats more than most people like in order to sit in a comfortable position. With my R, in order to have the seat reclined where I need it, it needs to be moved forward first, making my leg position very uncomfortable. In that position, I can't drive it more than a few minutes before having pain in my knees and feet. Instead, I've been driving with the seat moved aft and the seat not so reclined, but that causes my lower back to hurt after about 30 minutes of driving, even with the various adjustable support structures inside the seat.
I've read that the '18 and up seats are able to be both moved back farther and reclined better than my seats. If I were to purchase a newer seat, is it plug and play? The seat controls on the newer cars look exactly the same as mine, so I'm hoping it was just a seat re-design with the same functionality. My car is a coupe, and I don't remember the convertibles I test drove being as uncomfortable as mine is, but I was so excited when I found my car (I like the coupe's looks better), I hardly noticed the difference.
Old Nov 11, 2023 | 11:32 AM
scm's Avatar
scm
Have you thought of seeing an osteopath to see if they could advise on how to set the seat up? Cheaper option than changing seats if it works!
Old Nov 12, 2023 | 06:50 AM
uncheel's Avatar
The seats should be interchangeable, but I'd start by doing a test drive in a later model year and see if it helps.
Old Nov 12, 2023 | 10:32 AM
Thunder Dump's Avatar
The newer seats can't actually be moved back any further since the body dimensions and tracks are the same. However, because the newer seats aren't quite as thick, in their furthest position you do gain about 0.75-1" of extra leg/head room, which could make the difference or not. Just don't expect a significant amount of extra room.
One other thing to try is the 'creep' mode when moving the seats into their furthermost position back (or if the recline hits the back wall). If you just hold the button until it goes all the way back, the seat will actually 'bounce' forward a bit once it hits the back of the passenger cabin. Hold the lever to get you about 98% to full stop and then use the lever to just incrementally tap your way to fully backward (or reclined). The seat will hold that position and it can be saved.
Old Nov 13, 2023 | 01:50 PM
c131frdave's Avatar
I've been doing the tap mode for a while. I tap, tap, tap, get it better, better, better, and then it takes off forward again... I need just an inch or two more. I wish the pedals were adjustable. That would solve the problem entirely.
Rican
Sep 8, 2023 03:25 PM
oxendine
Apr 2, 2023 01:35 AM
LT1 jaguar
Oct 14, 2022 11:49 PM
notopm3
Jan 14, 2013 09:17 PM
f1champ
Jan 2, 2013 07:16 PM
