Newbie on Battery tender
Old Oct 27, 2018 | 08:19 AM
mzn50's Avatar
Default Newbie on Battery tender
Hello everyone.. i apologize in advance on this question but I did searches on the forum and saw multiple posts on how to install a Battery Tender on a FTYPE R
Now I think there are multiple ways based on model year and how many batteries your ftype has? ... I just am hoping someone can send me to a proper link to a 2017 MY hook up
it would be appreciated
Gas stabil is in and tires are overinflated to 40psi .. just hook up remains ... many thanks for all the inputs !
Matt
Last drive before storing !!
Old Oct 27, 2018 | 08:48 AM
Mulmur's Avatar
Going by advice from master mechanic at Jaguar dealer, I simply connect to the underhood positive/negative connections... easy and it has worked fine since 2016 when I first started the procedure.
Lawrence
Old Oct 27, 2018 | 09:26 AM
malbec's Avatar
Supplied by another forum member....
Old Oct 27, 2018 | 09:34 AM
mzn50's Avatar
thanks lads ... now either way have to figure out routing of cables ..?
thanks
Old Oct 27, 2018 | 09:53 AM
malbec's Avatar
thanks
If you have Ctek tender then just connect this bit. When you connect the tender the wire fits under the trunk lid with no problem.
Old Oct 27, 2018 | 10:47 AM
fujicoupe's Avatar
Banned
This is all so depressing, this talk of battery tenders and winter tires and salt on streets and ice and snow. I'm thinking that activity on this forum will drop to about the level of patronage at the local water park shortly. I shall miss the banter and camaraderie and technical discussions...until when? Next April or May?
Old Oct 27, 2018 | 11:14 AM
scm's Avatar
scm
I'm sure our southern hemisphere colleagues will keep us entertained!
Old Oct 27, 2018 | 11:57 AM
mzn50's Avatar
We're counting on it...my Carbon Fibre Defuser just shipped... and will be sitting in a box till may .... grrrrrrr..
thanks for the help everyone.. As per Mulmer-- I connected directly to ground and positive under the hood.. seems to be working..
Old Oct 27, 2018 | 12:25 PM
KVO's Avatar
KVO
Or a build in tender connection as per the Jag instructions:
DJS's Avatar
DJS
Just because my car will be in storage doesn’t mean I will be.
Old Oct 27, 2018 | 12:32 PM
Suaro's Avatar
One door opens, another door closes. Our car comes out in October, and goes away in May. Life in the desert.
Old Oct 27, 2018 | 12:43 PM
KVO's Avatar
KVO
Just wondering - is is too hot to drive the car in between May and October then?
Btw, no deserts in Belgium...
Old Oct 27, 2018 | 12:46 PM
Carlisle Owen's Avatar
Nice machine!! How long do you plan to store it?
Old Oct 27, 2018 | 01:03 PM
DJS's Avatar
DJS
Some great desserts (and beer), however.
Old Oct 27, 2018 | 03:14 PM
mlebofsky's Avatar
Would love a way to battery tend without having to pop the trunk each time.=left
No one has ever made a hidden, undetectable, external charging port?
Old Oct 27, 2018 | 05:40 PM
OzXFR's Avatar
You could do what I have done and fix the pigtail leads to the charging posts in the engine bay, see here: https://www.jaguarforums.com/forum/f...0/#post1710314
Then all you need to do is figure out a way of tucking the plug end of the cable up out of the way under the hood or in the wheel well in such a way that you can pull it out without having to open the hood, and so that it is easy to tuck away again and it sits firmly tucked away with no chance of falling down or out while driving no matter how bumpy the road. You will probably need to extend the cable(s) to achieve this.
If you find an easy and sure fired way to do this then let us know, I'm all ears!
Edit - I reckon I have solvered the problem.
The plug end of the charging cable/lead tucks in nicely between the curved part of the edge of the bonnet/hood (ie the top of the wheel arch) and the black plastic lining piece which sits under it. It's a tight enough fit so there should be no chance of it falling out while driving, yet it is easy to reach under with a finger (while pulling the edge of the hood away just a little) and flip it out, then place it back again, with the hood fully closed the whole time.
I'll give it a driving test in an hour or so and report back.
Edit 2 - update - have been for a spin on some fairly bumpy roads and success, the plug end of the cable didn't budge at all, still tucked away firmly under the edge of the hood.
Old Oct 27, 2018 | 06:30 PM
Mbourne's Avatar
Trust me the banter doesn't stop or slow down in fact it tends to increase as those that can't drive become even more obsessed waiting for spring.
Old Oct 27, 2018 | 06:42 PM
OzXFR's Avatar
I'm soooo glad I never have to think about storing the car for winter and I can (and do) drive on summer performance tyres all year with zero problems.
I have seen snow once in my life and I had to travel 1,500 km for that!
Old Oct 28, 2018 | 12:45 AM
NavyBlue's Avatar
In my previous Corvette, just plug into the always on electric plug in the trunk. Easy.
Don't understand why my wife's Mercedes & my current F-type doesn't offer the same easy-peasy always-on plug.
Old Oct 28, 2018 | 02:19 AM
KVO's Avatar
KVO
Cookies, desserts, pastry, beers, are us
Bugatti Veyron has an external hidden tender connection under the right tail light - to buy a Veyron just to have such though...
A nice solution would for instance be a connection behind a swiveling licence plate holder.
