Newbie on Battery tender
Old Oct 28, 2018 | 06:55 AM
scm's Avatar
scm
Electric vehicles seem to have solved the problem ....
Old Oct 28, 2018 | 09:26 AM
enfield's Avatar
It's not all bad. I stored my F-Type on Thursday. Filled up gas, inflated the tires to 45psi, put dryer sheets in the trunk and the cabin (heard an old husband's tale (or was it tail) that rodents don't like it,) and attached the battery tender using the ctek cables. Thought about steel wool for the exhaust and the air intake but elected against.
I have winter rated BF Goodrich T/A KO2s on the Range Rover Sport. Excited and looking forward to lots of snow!! I enjoy driving in the white stuff. My commute is, maybe, 5 minutes. So that's easy. Looking forward to weekends to go out and play in the snow!
Old Oct 28, 2018 | 09:32 AM
Carbuff2's Avatar
A friend has this magnetic connector on his two cars with battery tenders.
A great item if anyone in your family is in a hurry or forgetful!
The Mag Charger connections are a proprietary system that use a magnetic system to couple and engage power once coupled. It's amazing since you can't hook it up incorrectly and once disconnected no power at the car. It's also 100% water proof (can take pressure washing), dust proof, and hooks to the standard battery tender connectors. A simple mount that just slips on over the grille and can be removed anytime.
https://www.corvettecentral.com/prod...103-1.main.jpg
Old Nov 6, 2018 | 12:20 PM
Pie944's Avatar
Hi,
Do I connect the CTEK to the areas circled in white? If I use the eyelet connectors do I need to do anything special or just overlay them on the areas circled?
Thank you in advance.
Old Nov 6, 2018 | 01:36 PM
NavyBlue's Avatar
Another question:
I Use the CTEK battery tender on the front/under the hood main battery, do I also need to hook it up to the aux battery in the trunk separately also?
or does charging the main front battery takes care of both?
Old Nov 6, 2018 | 02:52 PM
Carbuff2's Avatar
The connections circled in white are proper. You can connect the positive side anywhere on that bus bar.
Does anyone know: What is that thing to the left of the ground wire, with the white/black wires connected?
Old Nov 6, 2018 | 04:15 PM
Unhingd's Avatar
I believe that’s where a number of smaller circuits are grounded
Old Nov 6, 2018 | 05:59 PM
  #28
Carbuff2's Avatar
That's what it LOOKS like...(I noted the big ground lug in the center.) But could the black 'collar' be a surge suppressor or something?
Perhaps a Dilithium Crystal???
https://en.wikipedia.org/wiki/Dilithium_(Star_Trek)
In the Star Trek fictional universe, dilithium is an invented material which serves as a controlling agent in the faster-than-light warp drive
Old Nov 6, 2018 | 06:13 PM
scm's Avatar
scm
Shhh! Everyone will want one ....
Old Nov 6, 2018 | 06:15 PM
  #30
Carbuff2's Avatar
I bet that everyone of us has one already! "MORE POWER, Scotty!"
Old Nov 7, 2018 | 12:17 PM
  #31
Nati's Avatar
Is it necessary to disconnect the battery before wiring to that bus bar? My beeping voltage tester doesn't alarm when I touch it to anything in there.
Old Nov 7, 2018 | 01:02 PM
  #32
Nati's Avatar
Never mind. I didn't die.
Old Nov 7, 2018 | 01:19 PM
  #33
mlebofsky's Avatar
no
Old Nov 7, 2018 | 02:55 PM
  #34
clubairth1's Avatar
Community Influencer
No the battery maintainers only charge the big battery. The secondary battery is charged by the car as the two batteries are isolated.
You could add a second charger but the small battery does NOT start the car so I don't see any point?
adrouin
US Western
Oct 27, 2018 02:38 PM
06-XJR
16
Jul 5, 2016 11:13 AM
fabfive
May 6, 2014 03:19 PM
D-squared
Jan 25, 2010 01:07 PM
GhostriderXKR08
Sep 3, 2008 09:57 PM
