Occasional belt squeal V6
Old Jan 13, 2020 | 12:50 PM
glenn b's Avatar
Default Occasional belt squeal V6
So my September 16 v6 occasionally makes a sound like a loose fan belt screech. Oddly it only does it at the first traffic light stop which is about 400yds from my house and only if it's from a cold start. The sound is loud and lasts about 3 seconds. I cannot recreate the noise at any other time. Anyone else had this?
Old Jan 13, 2020 | 04:29 PM
RGPV6S's Avatar
The only mention of belt squeal I have come across on this F-Type forum was from a replacement supercharger belt that was too long after a crank pulley swap.
The engine has pretty stout tensioners for the accessory and supercharger belts.
Did you or previous owner ever replace either belt?
Old Jan 14, 2020 | 01:50 AM
glenn b's Avatar
No i don't think anything's been changed. I po and 17k miles. I have full jag history showing 3 services but no extra work.
Old Jan 14, 2020 | 07:29 AM
Itismejoshy's Avatar
On the F-Type it could be as simple as belt wearing out (but not usual at 17k) or its a sign that something is starting to make one of the belt systems hard to turn. (Inner Belt : alt, AC, Waterpump, PS---Outer belt: supercharger or one of the idlers)....just keep an eye on it and see if any other "issues" correlate to the squeak. normally i would tell people to disregard a squeaky belt if it goes away...but its not common on F-types. What variant F-type do you have?
Old Jan 14, 2020 | 12:35 PM
glenn b's Avatar
It's a 3.0 s/c auto. Weird how the squeal is only at idle and doesnt occur when revving the engine like a typical loose belt would.
Old Jan 14, 2020 | 04:25 PM
Unhingd's Avatar
I had that problem with a bad belt. Got worse when cold outside.
Old Sep 10, 2020 | 05:54 AM
David Gregory's Avatar
Hi mate, did you get this sorted in the end? What did it turn out to be? I have the same issue and want to sort before the cold weather comes!
Old Sep 10, 2020 | 03:49 PM
Unhingd's Avatar
Have either of the pulleys been changed on your SC drive?
Old Sep 14, 2020 | 07:38 AM
glenno's Avatar
Hi. No the noise went away in the summer. I suspect it will come back now it's turning colder and damper. I need to get under the car and remove the trays and have a good look.
Old Sep 15, 2020 | 07:08 PM
Unhingd's Avatar
It will come back when the weather turns cooler. Don't waste too much time. Spend $50-80 on a new belt. They're easy to replace.
Old Jan 29, 2021 | 05:41 AM
shepjo's Avatar
I have exactly the same problem as you.
Did anyone get anywhere as to working out exactly what it was or what belt etc?
Old Jan 29, 2021 | 08:22 AM
Unhingd's Avatar
Generally a new belt will fix the problem.
Old Jan 29, 2021 | 08:42 AM
glenno's Avatar
I replied in his other thread. But both belts changed and all pulleys and tensioners checked. I still get an occasional squeel when it's been left unused in cold damp weather. Mine lives outside.
Old Jan 29, 2021 | 08:55 AM
Unhingd's Avatar
How long does it take to subside after you start driving?
Old Jan 29, 2021 | 08:58 AM
glenno's Avatar
It only does it once when I stop at the end of the street 100yds from home. That's it.
Robert Laughton
Dec 22, 2019 12:44 AM
David_h
May 11, 2014 09:29 PM
Bacardi 151
Sep 22, 2011 06:34 PM
dennisw
Aug 31, 2011 12:25 PM
ItsCain
Jul 19, 2008 01:54 PM
