Oil consensus
Old Feb 10, 2019 | 03:54 PM
Martyb's Avatar
Default Oil consensus
So I have read countless threads on the special oil that we are supposed to use for our cars. Is there any specific data that shows we are harming our engines if we don’t use the required Castrol product? Just got my car Friday, I want to go through it with fresh fluids and I am not convinced that Mobil 1 is going to hurt the engine. Also, I am in AZ, stick with 5-20 or go with 5-30 in the warm months?
Old Feb 10, 2019 | 04:18 PM
OzXFR's Avatar
I don't know of any specific data but I have never read about or heard of any AJ133 or AJ126 engine damage caused by using correct spec oil but not the Castrol Unobtainium.
I have been using Aussie brands Penrite and Nulon full synthetic 5W20 meeting the spec Ford WSS M2C945-A for many years now in both my old XFR and current F-Type with zero engine problems in either car.
IMHO the JLR insistence on using the Castrol brew is simply a marketing ploy and a way for dealerships to extract some extra $ from the customer when doing an oil change.
Old Feb 10, 2019 | 04:27 PM
JIMLIGHTA's Avatar
Banned
Light weight oils are used to help meet mileage reqrirements. Higher mileage or better engine protection. Your choice.
Old Feb 11, 2019 | 11:27 AM
Carbuff2's Avatar
One grade thicker won't hurt anything. @Martyb you could use either of the weights you mention.
Mobil1 Extended Performance meets the Ford specs as does Pennzoil Ultra Platinum.
Do our engines have variable valve timing? THAT can be a factor regards oil weight.
Old Feb 11, 2019 | 03:47 PM
OzXFR's Avatar
Yep, variable valve timing on both the inlet and exhaust valves on all AJ126 and AJ133 engines, JLR call it Variable Camshaft Timing (VCT).
Operated by solenoids rather than hydraulic.
The NA 5.0 also has two distinct intake camshaft profiles, again operated by solenoids. JLR surprisingly call it Camshaft Profile Switching (CPS).
It's all explained in the AJ133 Technical Training PDF, get it from my Dropbox here: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
Old Feb 11, 2019 | 07:25 PM
Carbuff2's Avatar
So, if it is controlled electrically (not by hydraulics) thicker oil shouldn't affect anything.
Some Chrysler engines are finicky about oil weight because they use hydraulic cam-timing systems.
Old Feb 11, 2019 | 07:34 PM
zach05855's Avatar
Yeah....another discussion about oil....
Old Feb 12, 2019 | 09:41 AM
Martyb's Avatar
i just asked a simple question if anyone had any any hard data to support the use of the magic Castrol oil. I read probably 20 different oil threads and didn’t get my answer, thus the reason I posted the question.
Old Feb 12, 2019 | 10:12 AM
sov211's Avatar
Two reasons: the Castrol Edge oils contain titanium as an anti-wear ingredient and second, the Edge Professional obtainable only through Jaguar contains a dye which not only reveals leaks but also supports warranty claims. I intend to use the Professional formulation until the end of my warranty but after that will likely do my own oil changes using the "standard" Castrol Edge available almost everywhere. So, why Castrol instead of another brand? No particular reason except that it is excellent oil and available at decent prices. Besides, that's what the oil fill cap says, and I like to keep my cars original😃
Old Feb 12, 2019 | 10:21 AM
Tel's Avatar
Tel
Jaguar don't service cars within warranty any more with Castrol Edge, this side of the pond..
They have a deal on with Mobil. It's now JLR spec.
Old Feb 12, 2019 | 10:43 AM
Martyb's Avatar
Local dealer here in AZ uses Pennzoil Platinum, I’ll be going that route.
Old Feb 12, 2019 | 02:55 PM
Paul_59's Avatar
Banned
Jaguar list the recommended oil as 0W20 specification STJLR.51.5122
Initially Castrol Edge Professional E 0W20
Matched but I believe this has been discontinued in UK and replaced with
​Castrol Edge Professional E C5 0W20​​​​​​
There are several other oils that match
STJLR.51.5122
Fuchs Titan GT1 EVO 0w-20
Mobil 1 ESP x2 0W-20
Motul SPECIFIC 5122 0W-20
RAVENOL ECS, 0W-20,
May be others in your region
My advice look for 0W20 to spec STJLR.51.5122
Old Feb 13, 2019 | 08:13 AM
zach05855's Avatar
if your car is under warranty then do as the manual says and you are safe. if warranty is over then do what you want, is's your car. Just don't complain if you have issues.
Old Feb 13, 2019 | 12:00 PM
Tel's Avatar
Tel
The manual and stickers/signs under the bonnet say Castrol Edge Pro, but mine was under warranty and the dealer is putting Mobil 1 in.
Guess the point here is to ensure that any oil you out in meets 5122 specs.
Also, another to consider is Liqui Moly from Germany:
https://www.liqui-moly.com/en/compan...over-2649.html
and from the UK:
https://www.opieoils.co.uk/pv-301975...20engine%20oil
Old Feb 13, 2019 | 12:25 PM
FType17's Avatar
Just another post filled with inaccuracies.
Oil weight is a factor of many things, from engineering tolerances to volume requirements, to of course any hydraulically controlled functions (not on the F-Type, but Chryslerand other use them for MD systems, camshaft phasing etc).
BMW M engines for example use higher weight oils, as high as 50.
In a lubrication system, oil temperature and PRESSURE are key consideration. The F-Type engines do a phenomenal job at keeping the oil cool. The oil rating is based on an upper temperature of 212 degrees, as that climbs and the oil drops in viscosity, so does the oil pressure. Likewise, an overly viscous oil will cause higher pressure than desired at operating temperature. 0W20 ensures easier starts (when cold it's 0). This also ensures that oil flows as quickly as possible to all moving parts almost immediately at startup (highest wear period).
Going to 5 is not ideal.... going over 20 should be only done when the oil runs consistently above 212 degrees (a temperature that the F-Type oil hardly reaches as it is).
I use Motul V300 0W20 on both my daily driven car and the race prepped ones with great results (and lower operating temperatures on top of it, 10-15 degrees cooler). This also reduces volatiles and crap going back to the intake....
Old Feb 13, 2019 | 02:33 PM
NavyBlue's Avatar
Jag dealer installed Pennzoil Ultra Platinum on my last oil change there, instead of Castrol.
Service advisor said in over 20 yrs at various dealership service dept, he has never seen any engine failures from any cars that's has regular maintenance with synthetic oil, no matter what the manufacturer or dealer uses/endorses: Mobil 1, Castrol, Pennzoil, or even Dexos, etc. It's all good stuff & it's all marketing!
Old Feb 13, 2019 | 04:50 PM
Alasdair 63's Avatar
Main dealer used shell helix ultra ow20 when I had my service done, dash cam recoded them filling it back up with 1litre bottles. I always thought they bulk buy and fill from a large drum.
Old Feb 19, 2019 | 02:55 AM
O'Dell's Avatar
I always use what the company recommends. With the Corvettes and AMG's, it was Mobile One, the Z4 got Castrol, and the same for the F-Types.
75Gremlin
Sep 4, 2014 12:02 PM
RoonieQ
Sep 28, 2013 01:12 PM
philhef
Aug 18, 2013 11:25 AM
Frog
Jun 29, 2013 02:30 AM
