Is this the oil to use?
Old Aug 26, 2020 | 01:23 AM
Ray Ray's Avatar
Default Is this the oil to use?
from rover parts, is this the oil to use for 2015 f type R? and which oil filter is the correct one?
Old Aug 26, 2020 | 07:08 AM
DJS's Avatar
DJS
Yes. Note that Rover Parts also has oil change kits - I use their 5W-20 kit, though it includes a quart more than I need as it’s for a Land Rover.
https://www.roverparts.com/search/Oil-change-kit/
Other threads discuss less expensive oil options.
Old Aug 26, 2020 | 07:30 AM
Rummy636's Avatar
I would make sure you need 0w-20 vs 5w-20. There's an engine split around 14-15 when they switched to 0w-20. Check your cap first.
Old Aug 28, 2020 | 03:59 PM
George05's Avatar
5w20 is fine just make sure you do an oil change every 3000mile all will be well
Old Aug 31, 2020 | 04:47 AM
Unhingd's Avatar
That’s a bit of overkill. I have each batch of used oil analyzed. Well over 1/2 of the additive package is still intact, viscosity is still as original, and the metals are well within tolerance at 8000 miles. Heavy track use should dictate more frequent oil changes, but oil changes at 6-8000 miles are safe for aggressive street use.
Sophi111707
Mar 8, 2020 03:54 PM
Zorac Dev
General Tech Help
Feb 15, 2020 05:40 AM
peppersam740
Jan 5, 2020 03:50 PM
xtypeofjag
Nov 8, 2014 08:58 AM
vandenplas408
Sep 25, 2014 03:48 PM
