Parts to change on used engine swap
Old Oct 12, 2024 | 03:20 PM
AldoRaine's Avatar
Default Parts to change on used engine swap
I’m going to be doing an engine swap in the next month. Does anyone have a good parts list of what I should go ahead and change before I put the replacement engine in?
Old Oct 12, 2024 | 05:55 PM
GaiaXF-V8S's Avatar
How many miles on the donor engine?
Old Oct 12, 2024 | 06:41 PM
AldoRaine's Avatar
The donor engine has around 80k miles.
Obviously I’m going to do the y-pipes, plugs, and probably injectors. Should I do the timing chains as well. Curious if there’s any oddball things I should change that are a pain in the *** to do if the engine is in the car.
Old Oct 12, 2024 | 06:54 PM
OzXFR's Avatar
Supercharger coupler/torsion isolator and oil change!
Old Oct 12, 2024 | 07:02 PM
GaiaXF-V8S's Avatar
Both valve cover and upper and lower timing cover gaskets would be a good bet. The passenger side valve cover has fuel lines that go over the top and is not fun to deal with while inside the engine bay. One of the fuel lines does not have a union, so the proper way is to fully disconnect it and in order to do that you have to remove the engine mount as the fuel rail snakes in behind the mount. I have seen videos of people bending the fuel lines out of the way, and while the fuel lines are robust, I could never recommend doing that.
Check the PCV valves in the passenger side valve cover.
Check for oil leaks all over, especially around the alternator area, replace alternator if oil found.
Inspect oil cooler for damage or leaks.
Inspect supercharger pulley for excessive play, maybe remove snout and inspect input shaft and upgrade to official Eaton solid coupler.
Personal opinion: Don't bother putting the Symposer in because it sucks anyways and makes the coolant pipe back there even more of a headache during replacement of the coolant pipe. VelocityAP makes a blank off plate.
Is the engine from a fellow 2015 F-Type?
Are you planning to re-use any parts from your old damage engine? Also, what happened to your original engine?
This is a great video of disassembly of the 5.0S if you haven't seen it.
Last edited by GaiaXF-V8S; Oct 12, 2024 at 07:06 PM. Reason: Added video link and added context
Old Oct 12, 2024 | 07:24 PM
diablo2112's Avatar
At 80K miles and with the donor engine so accessible, I'd do injectors and plugs along with the other suggestions here.
Old Oct 13, 2024 | 09:59 AM
AldoRaine's Avatar
https://www.youtube.com/watch?v=0MUHCvskzOQ
Thanks for the info! That’s exactly what I was looking for. Pretty sure the old engine spun a bearing or threw the timing chain. Dumped a bunch of oil and died idling in my driveway.
The donor is from an XF. I’ll swap over the relevant sensors and harness. I’m guessing the torque converter/flywheel is different. I’ll use whichever supercharger looks to be in better shape.
Old Oct 13, 2024 | 09:21 PM
OzXFR's Avatar
You could have a problem with fitting the gearbox depending on the year of the XF donor.
The early XF 5.0 SC came with the ZF 6HP28 and didn't adopt the ZF 8HP70 (same basic box as the F-Type) until 2012/13, and I reckon it is odds on that you can't whack an 8 speeder on the back of an earlier XF 5.0 without a custom adapter plate.
Old Oct 13, 2024 | 09:32 PM
AldoRaine's Avatar
I’m pretty sure that’s incorrect. The block is the same so it should bolt up. I wouldn’t be able to put the XF gearbox in my F-Type but my gearbox should bolt up to the block.
Old Oct 20, 2024 | 08:18 PM
Zen Beer's Avatar
didn't see the water pump mentioned
rumm5
May 28, 2023 11:19 AM
ericnunez
May 5, 2023 10:05 AM
tilbury
Aug 22, 2022 09:54 PM
Vaughn
Sep 23, 2021 12:36 PM
thedebs53
Feb 20, 2017 04:13 AM
