Pcv valve replacement
Old Jan 4, 2026 | 03:33 PM
Jbrush's Avatar
Default Pcv valve replacement
There is not much clearance to remove the PCV valve diaphragm, but it looks possible. Does anyone know if anything needs to be removed before I start the project? I just do not want to get the diaphragm popped off only to find out I would be unable to install the new one. I have the V8 model with two PVC diaphragms next to each other.
Old Jan 4, 2026 | 07:24 PM
RoverJoe's Avatar
Community Influencer
They come out without removing the supercharger, but it's tight. You will have to break the clips off the old one and rotate it out usually, the new one you will have to stack the spring/diaphragm carefully and line it all up in the slot, then I usually use a screwdriver or trim tool to push it down gently to latch all the tabs, one at a time.
Ryan Newbauer
Mar 5, 2025 04:05 PM
Anbran
Apr 29, 2023 09:09 PM
Spurlee
Mar 7, 2011 03:02 PM
toshack
Feb 5, 2010 10:40 AM
Oldengineer
Apr 11, 2009 03:48 PM
