Permanent dashcam install : anyone done it?
Old Oct 17, 2014 | 01:05 PM
bluebird's Avatar
Default Permanent dashcam install : anyone done it?
Got a new dashcam and will be looking for a decent auto electrician to permanently wire it. Anyone here done this yet? Did you link it to the fuse box or splice it to the 12v power adaptor?
And was it easy to route the cable behind the pillar facings? Pics would be really appreciated
Old Oct 17, 2014 | 05:28 PM
New2Jag's Avatar
Please post pics, I have been wanting to do this forever. Would have saved me a few times.
Old Oct 17, 2014 | 09:37 PM
shift's Avatar
Someone on the forum did a custom install for radar detector. Search for that, think he had to also run a line for power.
Old Oct 18, 2014 | 10:47 AM
F-typical's Avatar
Perhaps if you were to use a head, or helmet mounted GoPro?
Old Oct 18, 2014 | 12:07 PM
New2Jag's Avatar
That was me.
Passport Escort Max with direct wir/Bluetooth. Mounted next to rear view mirror...
Old Oct 18, 2014 | 12:10 PM
New2Jag's Avatar
I didn't think to comment on the install.
The wire is ran in the grove where the headliner meets the window and then down the drivers side a pillar. To be honest, I don't know which specific cable it was connected to, but I can tell you it was in the center console. There is a panel that comes off relatively easy. My XJL had the same type detector installed but it was hooked up to an accessory wire that remained on for 3 minutes after shutting the car down.
If you find a good, non obtrusive and non ugly dash cam.... Just take it to a car audio shop. Prolly cost you $75 bucks.
Old Oct 18, 2014 | 12:18 PM
another_geek's Avatar
I have a passport max installed in my car also. Installer found switched power in the overhead console - no need to run wires down the pillar to the center console.
Old Oct 18, 2014 | 01:07 PM
lunagry's Avatar
Banned
Do you know the radar detector rules for California? I'm thinking of getting one.
n/m found it.
Old Oct 19, 2014 | 02:20 PM
New2Jag's Avatar
Maybe he used the wire in center console because of the mute/mark switch. Where is yours installed?
Also. When you are playing music thru BT, does the Max always play audio thru the system when it's connected? Mine only works sometimes. With top down and radio up... I sometimes miss alerts.
H20boy
Dec 24, 2024 03:23 PM
philwarner
44
Nov 5, 2024 06:29 PM
Majik Lasers
Aug 2, 2024 01:49 AM
Dagny
Jun 11, 2024 01:06 PM
ericjansen
Dec 19, 2021 12:20 AM
