Phone holder for F-Type
Old Nov 12, 2021 | 06:14 PM
  #121
harryf's Avatar
Here is the follow up on mine. Placement look which is non intrusive and the view of my case with the metal plat inside of my case. Holds really strong.
Old Nov 12, 2021 | 06:20 PM
  #122
harryf's Avatar
here is the mount. It didn't get uploaded.
Old Jan 3, 2022 | 06:58 PM
  #123
cwisenheimer's Avatar
After looking at all the suggestions in this thread and then visually evaluating all the potential interior real estate in an F-Type, I realized that I wanted to mount my phone on the headliner in the space between the visor and the sunroof opening. I tried to think of how to effectively attach something in between the headliner and the windshield header structure and then decided to look at Amazon, where I found this:
Jebsen's Magnetic Phone Mount Jebsen's Magnetic Phone Mount
. It's perfect for what I wanted (and cheap too!). I simply removed the adhesive protective film, opened the sunroof cover (although there's plenty of space without doing so), and slipped it into the gap between the headliner and the hidden structure behind it. The mount holds the phone just fine in portrait or landscape and is securely positioned and it doesn't interfere at all with the sunroof cover. The only drawback to this mount is that it does not include charging, wireless or otherwise. That's not a big consideration for me in this car anyway. I've attached pics of the mount before and after installation and pics of an old phone mounted in portrait and landscape (I had to use my current phone to take pictures). I hope this helps.
Old Jan 4, 2022 | 04:20 PM
  #124
Uncle Fishbits's Avatar
My "grab bar" one just broke, and I want it back to being closer to line of sight, and this is interesting.
It's pretty amazing they've had nearly 10 years with this car and the rise of cellphones to not solve this annoyance for us.
Old Sep 26, 2022 | 03:40 PM
  #125
Michael211's Avatar
I like this unit a lot. I've taken several 1,000+ mile trips with it and had zero issues. Never falls off, never gets in the way, and it's up in your line of sight so you don't have to look down. And It doesn't require anything hard to reverse like a stick on pad.
LISEN Magnetic Phone Holder for Car Mount Upgraded Clip Cell Phone Holder Car 360°
It is on Amazon, but for some reason when I try to put in a link here it does not work.
Some people have disliked vent mounts like this because they feel it blocks airflow, but I have not found that to be an issue even in Nevada in the summer. The phone stands off from the vent enough that it really does not block it. I like this location for the power cord routing as well. Run out the back of the center console cubby, tuck under the console trim running forward, loop over the steering column, and the cord hangs right were you want it.
Last edited by Michael211; Sep 26, 2022 at 03:46 PM. Reason: Amazon Link acting weird
Old Sep 26, 2022 | 05:02 PM
  #126
DJS's Avatar
DJS
How did you get a speedo in KPH in the US? (Or does your car do 300MPH? )
Old Sep 26, 2022 | 05:13 PM
  #127
Michael211's Avatar
It's a Canadian car, eh?
Old Sep 27, 2022 | 10:18 AM
  #128
ViperX100's Avatar
Love this cell holder. No need to use the vents, keeps the dash clear, good angle for the driver, and the magnet holds very securely.
https://www.etsy.com/listing/1123306569/jaguar-f-type-cell-phone-mount-holder?click_key=4afeeb6f168991122c1d0c823b5d0707c 68462da%3A1123306569&click_sum=2e121743&ref=shop_h ome_recs_1&crt=1
Old Sep 27, 2022 | 12:05 PM
  #129
ToysARs's Avatar
Doesn't this mark the leather underneath? Phones are quite heavy these days, I wonder if this could permanently compress/depress the leather/vinyl.
Old Sep 27, 2022 | 12:29 PM
  #130
ViperX100's Avatar
it’s actually quite gentle on the leather. It’s up to you how tight you want to wrap it but it’s very soft material for that reason.
powerhouse
Mar 11, 2022 07:25 PM
SVR 575
May 20, 2021 02:45 PM
eeeeek
Feb 16, 2020 12:28 PM
amouch
Nov 12, 2017 03:01 PM
LT Cav
Aug 18, 2017 06:43 PM
