Question about shift paddles
Old Aug 3, 2015 | 08:26 PM
Frenchy's Avatar
Default Question about shift paddles
Question about the shift paddles in the V6S auto MY 2016.
The manual says: "The gear shift paddles can be switched on and off, and configured to operate in 'S only' or 'D and S' via the Vehicle Settings menu" (p. 87).
I understood the first part of that quote to mean, well, what is says: that the paddles can be turned off, i.e. rendered non-functional. Which is what I wanted and tried to do. But I found no setting to switch them off. Just "S only" or "D and S." What am I missing? Can they be turned off?
Thanks.
Old Aug 3, 2015 | 08:42 PM
Stohlen's Avatar
nope, you can only turn them off in D.
Old Aug 3, 2015 | 08:44 PM
Unhingd's Avatar
Thanks.
If you select "S only", the paddles will be disabled when in D. You cannot disable them for the S mode.
Old Aug 3, 2015 | 09:53 PM
Foosh's Avatar
That is correct for all AT models.
Old Aug 4, 2015 | 01:28 AM
LoneAspen's Avatar
I just wish pulling both would put it in Neutral, like on some cars. It would be nice to be able to put it in Neutral quickly to blip the throttle sometimes.
Old Aug 4, 2015 | 01:02 PM
F-typical's Avatar
The shift lever does that.
As to disabling the paddles, it depends on how you've set the car up. If you set it so that the paddles are only active in S, then moving back to D will disable them. If you set it so they're active in S&D, the gearbox will revert to full auto if you don't use the paddles. In both modes, it starts off in full auto and only switches to paddles if you start using them. HTH.
Old Aug 4, 2015 | 01:17 PM
Arne's Avatar
Holding the right paddle in for a second or two will also revert it to full auto.
silkcat
Jan 18, 2025 04:29 AM
1LowCat
Feb 23, 2016 07:19 AM
user 652867429824
Oct 28, 2015 10:18 AM
1LowCat
Sep 14, 2015 07:51 PM
AtholC
Sep 9, 2015 09:07 PM
