Quick tire fitment question.
Old Jan 6, 2019 | 07:50 AM
Dibi's Avatar
Default Quick tire fitment question.
I know this has been covered a lot but I had a question on tire fitment. I just ordered a set of Ferrara FR8 wheels for my Jag. 20x9 35 and 20x11.5 30. I’ll be running Mich 4s tires. The sales rep said To go with a 305 30 in the rear. I noticed that the cars with the same set up are running 305 25 in the rear. Just wondering if this will be a problem. The car is dropped on H&R springs.
Thank you again for all the info within this community.
Old Jan 6, 2019 | 09:24 AM
Itismejoshy's Avatar
Go through alot of tires. What I have noticed is the stock 295 PZero sidewall is very round and with the H&R springs plus 15mm spacers it will rub slightly on full compression, the 4S does not with the same setup. Without spacers the 305 4s fits fine.
Old Jan 6, 2019 | 12:04 PM
Unhingd's Avatar
Please clarify: Are the numbers behind the wheels sizes the wheel offset or the tire profile?
If offset, you will likely have exterior tire rub in front under full compression in a tight turn.
I know of no one running 25 tire profiles on 20” wheels in back. You will want to use a 305/30-20 tire. With the 30 offset you listed above (assuming that’s the offset) you’ll have no issue with rub.
Old Jan 6, 2019 | 12:40 PM
Dibi's Avatar
Unhinged. Those are wheel offsets. Sorry if that was unclear. I did notice one person with these exact wheels running PZeros with a 25 sidewall. I couldn’t find any other tire size information for other members who are running these wheels with the same exact specs as mine.
Old Jan 6, 2019 | 12:45 PM
Dibi's Avatar
Thank you.
I’m looking forward to getting these wheels on the car. I’m concerned I may have to change the springs. I live in the northeast and the drop may unsuitable for the roads out here. But I’m gonna give it a go since I already purchased them last year.
Old Jan 6, 2019 | 12:57 PM
jaguny's Avatar
Is anyone running 11.5 inch rear wheels?
Old Jan 6, 2019 | 01:31 PM
Dibi's Avatar
https://www.jaguarforums.com/forum/f...f-type-183040/
The thrird and fourth cars have 11.5 inch rears with ferrada wheels. This is where I got my specs from.
Old Jan 6, 2019 | 03:12 PM
Unhingd's Avatar
It’s hard to find 315 tires to match an 11.5” wheel width.
Old Jan 6, 2019 | 03:21 PM
Dibi's Avatar
I’m going to be running a 305 not a 315. But i can always try and find a 315. Never seen anyone here run that width.
Old Jan 6, 2019 | 05:12 PM
jaguny's Avatar
Thanks, I am remember those!
Old Jan 6, 2019 | 05:52 PM
Unhingd's Avatar
An 11.0” wheel is the right width to optimize the contact patch on a 305 wheel, but an 11.5” will still be within the range of wheel widths recommended by the tire manufacturer. Pirelli and Toyo offer a 315 tire - the width best suited for an 11.5” wheel.
DaveC
Apr 26, 2013 01:41 PM
calviroman
Jul 30, 2012 08:42 PM
rweber
Aug 24, 2010 08:19 AM
Translator
Jul 29, 2010 10:39 PM
vagearhead
Mar 10, 2009 10:13 AM
