Rattle(s) driving me crazy- need help!
Old Oct 8, 2018 | 11:40 PM
adent's Avatar
Default Rattle(s) driving me crazy- need help!
Hi all great forum- I have spend hours reading threads on here both before and since getting my car (2015 V6S coupe AWD storm grey)
However I'm now having problems with a rattle from under the bonnet which is driving me crazy. I took the car for its last warranty service and reported this problem but a combination of it's intermittent and they weren't really able to replicate plus there is an aftermarket exhaust which they blamed meant it wasn't fixed....
so looks like I have to try and work this out myself... here's the clues. if anyone can help me solve this theres my gratitude and booze in it for you!:
1. quite high pitched metallic rattly noise intermittently
2. from under the bonnet but seems quite close to dash
3. occasionally when i go over bumps or uneven road i hear a rattle which sounds like the same thing. sounds like a metal rod or coat hanger rattling against metal.
4. when it really gets going it's most noticeable at IDLE when it sounds like a fluttering spinning rattle, like something driven off the cam. this happens in gear and in neutral or park and can get loud- it's intermittent but happens most drive over half and hour -- everyone who's been in the car comments on it (except of course the service guy when it didn't happen..)
5. weirdly, when its really rattling at idle, it will usually go away if i turn the steering wheel???
This is really killing me- i don't care if parts have to be replaced... I'm thinking: tensioner? aircon (happens with this off though)? ?supercharger? something with the steering??
Any help would be so gratefully received.
adent
(ps- there's another buzz thats a problem but maybe leave that for another post...)
Old Oct 9, 2018 | 12:05 AM
OzXFR's Avatar
A strange one for sure.
Lots of those symptoms sound like it's the classic torsion isolator/coupler rattle, but others suggest otherwise (close to dash, going over bumps, goes away with turning the steering wheel none of which make any sense if it was the coupler).
Sounds more like a loose exhaust heat shield, in the central tunnel just after the cats/downpipes.
Get it up on a hoist and poke around in that area.
Old Oct 9, 2018 | 12:10 AM
adent's Avatar
Thanks oz- that does sound like a possibility- especially seeing as prev owner had an exhaust mod done. i'll check it out. thanks
Old Oct 9, 2018 | 01:09 PM
KVO's Avatar
KVO
As one suffering from tinnitus, I can only say - the less attention you pay to a sound, the less it bothers you...
But of course, your car should be rattle free
Old Oct 10, 2018 | 10:48 PM
ndabunka's Avatar
adent
Search prior threads. Pretty certain your symptoms are nearly IDENTICAL to another whom had his supercharger (I think) replaced under warranty. Try a number of different search terms like "engine rattle" or "supercharge noise", etc
Here are a few I found "Supercharger coupler" is the one I thought sounded familiar
https://www.jaguarforums.com/forum/f...rattle-194718/
https://www.jaguarforums.com/forum/f...500rpm-202506/
https://www.jaguarforums.com/forum/f...-ideas-198194/
Old Oct 11, 2018 | 08:29 AM
DJS's Avatar
DJS
Here's the TSB for the supercharger issue, but it only applies to the V8. Don't recall if anyone's had this issue with a V6...
https://www.dropbox.com/s/4itzi5b6rw...Noise.pdf?dl=0
Old Oct 11, 2018 | 09:12 AM
Unhingd's Avatar
https://www.dropbox.com/s/4itzi5b6rwwqpdo/JTB00349v2%20-%205.0L%20Supercharger%20Noise.pdf?dl=0
I believe it's only been an issue with the TVS1900 supercharger.
Old Oct 11, 2018 | 06:33 PM
OzXFR's Avatar
Nup, also applies to the TVS1320 (??) on the V6, I had the snout/coupler replaced on mine under warranty about 18 months ago and there is a separate TSB for the V6, JTB00356NAS1 attached below (although there could by now be a later version).
I posted about it on another thread somewhere and commented that I couldn't really detect much if any change in the rattle after the "fix".
Old Oct 12, 2018 | 09:11 AM
DJS's Avatar
DJS
Too low-rez to be legible, unfortunately. However, Google pointed me to another forum where you posted legible images.
https://www.jaguarforum.com/showthre...=1#post1065505
From your Dropbox to mine - thanks.
Old Oct 13, 2018 | 09:09 AM
Miauuu's Avatar
I'm having a similar buzzing metallic rattle above 4K rpm, someone suggested looking at the metal AC line running along the driver's side of the engine bay and adding some rubber isolator.
Old Oct 13, 2018 | 10:18 AM
DJS's Avatar
DJS
Active exhaust vacuum pump makes a buzzing metallic sound, though I can only hear it closer to idle. You could temporarily pull fuse F43 (under the passenger footwell) to see if that’s it.
Old Nov 2, 2019 | 12:26 PM
conbrash's Avatar
adent
Hi, I have gone through 50 plus rattle threads on here reading all the issues. One member had a similar rattle under the bonnet and what fixed it was tightening the clamps that lock the hood down. They can become loose and cause a rattle.
hope that helps
mfennell
Jul 30, 2019 10:43 AM
croco
Jul 28, 2017 11:50 PM
User 070620
Jan 29, 2013 03:45 AM
ramair57
Mar 12, 2012 10:00 PM
fwilder
Jan 20, 2012 09:56 PM
