Rear Camera Cable
Old Oct 20, 2020 | 02:34 PM
art.vandelay's Avatar
Default Rear Camera Cable
I recently purchased an F Type R. I noticed that the backup camera was not working so I took it to my dealer. They said whoever changed the battery accidently cut the camera cable. The dealer says they have to replace the entire harness from the trunk to the dash and labor alone is $4750. Seems like I should be able to just find the cut wire and splice it. Anyone have any opinions on whether that should work?
Old Oct 20, 2020 | 10:05 PM
bjg625's Avatar
I suspect your right but dealer proably not allowed to do that. My experience with a faulty door handle sensor suggests Jag sells only full assemblies. Decent foriegn shop can probably find and fix.
Old Oct 20, 2020 | 10:10 PM
Mbourne's Avatar
+1. Also, great user name. Are you a latex salesman or an architect?
Old Oct 21, 2020 | 08:06 AM
fujicoupe's Avatar
Banned
My guess would be importer/exporter.
Old Oct 21, 2020 | 09:14 AM
Rummy636's Avatar
They recommend the harness cause its a coax type cable and isnt just repair and work. Its also a one piece cable which makes it the whole harness. Never had luck trying to repair coax type cable either.
Old Oct 21, 2020 | 10:56 AM
scm's Avatar
scm
Not even with a plug and socket?
Old Oct 21, 2020 | 11:46 AM
Rummy636's Avatar
Its not your typical coax cable if you look at it
Old Oct 21, 2020 | 06:47 PM
Yep.....I once tried to be a marine biologist but that didn't work out.
Old Oct 21, 2020 | 06:49 PM
You are correct. I got the car back today and sure enough, someone pinch the cable with the battery tie-down and snapped it. I snipped off a piece of the cable and it's coax or fiber-optic. Either way, not looking good as far as an easy fix.
Old Oct 21, 2020 | 09:15 PM
bjg625's Avatar
Definitely worth seeing if plug could solve problem. Maybe a cable guy?
Old Oct 21, 2020 | 10:00 PM
Unhingd's Avatar
If it’s a fiber optic cable, a splice or connector will not suffice. It will require a powered junction box. Your local Verizon Fios technician could probably get you sorted for a lot less than $5k.
Masternorth
Oct 4, 2019 10:24 PM
Paul Winfield
Oct 31, 2018 11:21 AM
Tandemcha
Oct 14, 2015 08:25 AM
andreastrones
Oct 31, 2014 05:16 AM
