Rear SVR diffuser/valance install on R?
Old Dec 21, 2020 | 03:19 AM
Guardian's Avatar
Default Rear SVR diffuser/valance install on R?
Question:
is it possible to install SVR lower diffuser part (instead of whole diffuser) on the R ?
I want to replace/swap just this lower part:
https://cimg0.ibsrv.net/gimg/www.jag...1492277504.jpg
I assume YES if only the p/n of the upper part of SVR diffuser is the same as upper part of R diffuser - can anybody check this?
Thank you
Old Dec 21, 2020 | 09:35 AM
Therock88's Avatar
Originally Posted by Guardian
Question:
Thank you
I would say, YES. I saw some posts on a Facebook F-Type forum that has pictures of people that have done it. I was thinking of doing the same, but cannot verify if I would need just one of these parts or both? And which one?
Anybody know...appreciate the advice.
Thanks,
DC
Old Dec 21, 2020 | 02:26 PM
mrjohnt's Avatar
Would love to know the answer to this as well. The SVR rear valence looks a little bit more aggressive with the center part that the R is missing. Plus I want to keep the car as OEM as possible.
Old Dec 21, 2020 | 03:16 PM
Luis Tellechea's Avatar
i think part #8 is all you will need. part 14 is for the space underneath. the svr has two side mufflers, while the r has a big suitcase in the middle. I think part 14 is to cover the hole that the SVR would have due to the side mufflers.
Old Dec 21, 2020 | 03:34 PM
Guardian's Avatar
Yes, you are 100% correct.
All is needed is part no. 8
Old Dec 21, 2020 | 05:06 PM
Therock88's Avatar
Here is one of the FB posts I remembered seeing...Guy actually updated the exhaust of a V6 and added SVR Diffuser.
https://www.facebook.com/groups/7929...86051758085115
And here is another...I am thinking it may work,k and thinking I may have found a new project
https://www.facebook.com/photo.php?f...4328658&type=3
Going to have to give this some serious thought! No guarantee, but looks possible?
DC
Old Dec 22, 2020 | 04:30 AM
mrjohnt's Avatar
DC
if anyone can do it, it’s definitely you!
Old Dec 22, 2020 | 05:02 AM
Guardian's Avatar
Just ordered mine but I hope Therock88 will be even faster with his outstanding DIY
Old Dec 22, 2020 | 09:25 AM
madmax1911's Avatar
Great, another mod I didn’t know I needed. Thanks for blazing the trail here guys, will be following with interest.
Old Dec 22, 2020 | 10:10 AM
Ray Ray's Avatar
anyone tried just sticking some plastic diffuser blades to the mid section with 3m tape? If done right it should give a factory yet customized look, for a hell lot less.
Without it does R does look like something is missing in that area.
Old Dec 22, 2020 | 10:37 AM
Therock88's Avatar
OK...Great! Now the pressure is on Actually still researching part numbers etc., and have not ordered anything yet (Just put the car back together after Sprint Booster install, Transmission Fluid Change, and Differential Fluid Change)...Need to keep my ratio up, of 2 mods to 1 drive...Haha
I have not been able to verify yet if the valence pice is needed. It appears it may be based on different parts numbers? I will still be able to provide you with lots of help and documentation (best I can) until I get to doing mine. I have listed part numbers below, and why I think a valence 'MAY" be needed? Perhaps Guardian can confirm when he gets his part, before ordering the second piece (or not).
So when I compare F-Type R and F-Type SVR Rear Bumper parts per the images below...the two different ones are the valance and lower panel (Under Cover as they call it). I am also going to reach out to the FB guys to see if they can answer.
I will also see what Shop Manual I can acquire from my prior Auto Business and will post more here as I get it...
So the parts...I put images with color-coding...Hope this makes sense.
DC
** Likely not needed
Old Dec 22, 2020 | 11:37 AM
mrjohnt's Avatar
DC
Thanks again fellas! Let us know what happens. I need a winter project. Hopefully it’s not too costly?
Old Dec 22, 2020 | 11:41 AM
mrjohnt's Avatar
I’ve seen this done on an R for sale on eBay in Illinois. I thought it was an aftermarket valence and upon further examination, it was those plastic fin pieces you can get on eBay. Honestly looked fine until you examine the pictures better. one fin was crooked and it looked difficult to line up flush with the edge of the valence. Wish I kept the pictures. Feel free to give it a shot?! They are priced pretty cheap.
Old Dec 22, 2020 | 12:13 PM
Ray Ray's Avatar
any link? I think the hard part is matching the curvature to the mounting surface.
Old Dec 22, 2020 | 12:17 PM
Therock88's Avatar
Well...If you just need the Under Cover Panel...The list is ~ $795 (can get it for under $600 ish). If the Valence is also required, it adds ~$720 List (available for less than $550). I would estimate the painting to match to be around ~$350.
So retail ~ $1965 with shipping and painting. And likely around ~ $1200 based on available discounted pricing. Waiting to hear back from a guy on FB to see if 1 or both parts are needed...Then I may order. I have only spent ~ $16,000 on upgrades and maintenance so far this year, so why not
DC
Old Dec 22, 2020 | 12:23 PM
Therock88's Avatar
Yes...I have experimented with a couple of sacrificial Corvette Diffusers and really hard to trim the curvature perfectly (not enough for my taste anyway). It can be done, but I think the SVR will yield a more professional look. I may keep tinkering with the Vette ones too for fun until I run out of donors.
DC
Old Dec 22, 2020 | 12:45 PM
mrjohnt's Avatar
DC
I’m ok with this pricing considering genuine parts, near perfect fitment, and requires no modification. I’m not ok spending over $1000 plus for a carbon fiber rear valence that would fit terrible and/or crack over time and require another $1000 in bodywork just to make it look good. I had a Vorsteiner valence on the C63 and it fit terrible and cracked. Never again!
Old Dec 22, 2020 | 12:52 PM
Therock88's Avatar
Agree. That Vorsteiner (and many other aftermarkets) stuff is crap! And way overpriced. Dealt with the same issue on my 997 TT and Boxster S... And just like the Project 7 Grille and Sport Rear Wing on the F-Type, it all fits perfectly, and the Auto Body shops have no issues painting them to perfection!
DC
Old Dec 22, 2020 | 12:55 PM
Therock88's Avatar
Since one or more of you will likely beat me to this project, and I will not be able to complete a DIY beforehand, I have pulled some basic shop manual info on rear bumpers together and put it on my shared drive, which I hope will help some.
Good luck.
DC
INFO HERE
Old Dec 22, 2020 | 03:34 PM
mrjohnt's Avatar
DC
Off topic question DC, you seem to have a wealth of knowledge on the Ftype, what do you think about the 400 Sport front splitter under the front bumper? Do you think that would fit? It has been asked before with no real responses.
