Red Line Water Wetter
Old Nov 3, 2018 | 11:56 PM
mlebofsky's Avatar
Default Red Line Water Wetter
Any cons?
Thoughts?
1 bottle to our all-ready 50/50 mix?
Old Nov 4, 2018 | 05:42 AM
SinF's Avatar
Water wetter is really delivers improved cooling in racing. However, long-term effects are unknown. I can't tell you what engine with 100K with it would look like internally. Are there deposits? Does it turn acidic and eats coolant passages?
Old Nov 4, 2018 | 07:00 AM
Carbuff2's Avatar
SIGH <--- another common topic that generates endless discussion, wherever
Don't forget Evans Waterless Coolant https://www.evanscoolant.com/how-it-...rless-coolant/
I'm not making recommendations, I just use the type that the manufacturer says. (My garage cabinet has three different coolants, for four cars!)
Whatever you use, you need to consider your OWN needs:
freeze protection
boil-over resistance
what your engine is 'made of' (iron, aluminum, etc)
availability
cost
(Would you rather talk about oil???) LOL
Old Nov 4, 2018 | 08:50 AM
mlebofsky's Avatar
freeze protection
availability
cost
SIGH - I've read a lot about oil on our forum … Was hoping to get first hand, measured experience of Water Wetter with our F Types.
Old Nov 4, 2018 | 09:01 AM
lizzardo's Avatar
I've used Water Wetter in all my race bikes except one (air cooled), mixed with water only. Did the bikes run cooler with it? Not that I noticed, but before the sanctioning body permitted it, I drained the cooling system after each race weekend to avoid corrosion. Afterwards I didn't bother with that. I have not tried it in the F-Type.
Old Nov 5, 2018 | 10:56 AM
eeeeek's Avatar
Yep. The only reason I ran water wetter is that for racing, we were not allowed to run glycol. With that in mind, I ran Distilled Water and a few capsfull of water wetter. I don't see any benefit of running it in a car that has anti-freeze.
Old Nov 6, 2018 | 10:39 PM
O'Dell's Avatar
I had four Corvettes in a row between 2007 and 2014, and most Corvettes tend to run hot in the summer - 220 to 230 degrees in traffic. I kept the oil temp gauge on the dashboard all the time and if it was reasonable, I ignored the water temp. I did try the Water Wetter once about ten years ago, and noticed no difference at all. Since my F-Type's temperature gauge parks itself right on normal winter or summer, I seldom think about it.
Old Nov 7, 2018 | 09:05 AM
SinF's Avatar
Unfortunately, temp gauge has nothing to do with engine temp on F-type. It isn't representative of actual engine temperature. F-type has "too hot" and "cold engine" lights that were made into a fake gauge. To make things worse, F-type's engine is not likely to survive severe overheating, so when you gauge pegs it is generally too late.
Old Nov 7, 2018 | 12:50 PM
O'Dell's Avatar
Hmmmmmm. I'm fairly new to Jaguars, a bit over a year, and that seems like an odd way to report on the engine's condition. Obviously, I've never seen a "too hot" light, but it's something I need to investigate. I guess my first question is why put a gauge prominently on the dash, if it's output is inaccurate. Is there a way to display or even see the oil temp rather than the coolant temp like I did on my Corvettes? Now you have me concerned, but thanks for the information.
Old Nov 7, 2018 | 01:45 PM
mlebofsky's Avatar
I have read a lot of mixed reviews with regards to adding the product to an existing 50/50 mix. Everything from "great addition, lowered temps" to "caused sludge build-up" ....
Old Nov 7, 2018 | 01:46 PM
FType17's Avatar
My experience with water wetter is some what different. I first used it around 1998 in my C5 Corvette and it was mostly because the fan cycled a LOT when going to work (same traffic every day). Upon switching to water wetter, I noticed that the fan came on less.
I then started using it on my modified Honda VTX1800N3 and Hayabusa Turbo. On both, the fan cycled a lot less. I still use it on all my vehicles
The point of it is NOT to make the engine temperature lower, because that is controlled by your thermostat and you would NEVER see a change in teh gauge. The point is to increase the heat transfer ratio. This is heat from the block to the coolant and then the coolant to the radiator for fast heat dissipation.
No an engine temperature gauge is not going to show you any change, the real proof is how well it transfer the heat to th radiator elements for cooling.
PS, I disagree with the post above. The Temperature gauge is actually a GAUGE tied to the coolant temperature sensor and showing exactly the coolant temperature in the block. If in doubt, hook up an OBDII scanner with real time data and you can observe the temperature climb on both at the same time
Old Nov 7, 2018 | 02:09 PM
mlebofsky's Avatar
FType17 - Can you check your private message section?
Darrenmb
Feb 3, 2015 04:57 PM
wa3ra
Oct 10, 2014 07:51 PM
Nighteyez
Oct 23, 2013 04:30 PM
Cerberus66
May 24, 2012 06:44 PM
Innovative Detailing
Detailing / Car care
Feb 5, 2010 12:09 PM
