Remove Interior Pieces
Old Jun 5, 2021 | 11:57 AM
narey's Avatar
Default Remove Interior Pieces
Hey guys,
Does anyone know how to remove these interior pieces? (the 2 left and right plastic window switches and the passenger boulster plastic insert)
I have attached pictures of what I'm talking about - do they just 'snap' off (clipped in), or does it require centre console removal or door card removal?
Thanks!
Old Jun 5, 2021 | 01:48 PM
xdave's Avatar
I recently did those to replace the soft touch parts with the later hard coat ones.
The grab handle is the simplest - it just pulls off. It is held in with sprung plastic hooks and comes off sideways. Be careful not to damage the little wires for the LED strip above it.
The window switches are a bit harder. You need to remove the interior door panel, then there are a bunch of torx screws on the reverse of the panel to remove. I remember a handful being quite deep to get to so you'll need a long shafted driver/key.
File Type: pdf
Old Jun 5, 2021 | 02:05 PM
62jeff's Avatar
Sideways towards the passenger or sideways towards the shifter console?
Old Jun 5, 2021 | 02:30 PM
xdave's Avatar
Towards the centre/shifter. If you look carefully at the outside edges you will see they are shaped to fit and can only come out one way,
Old Jun 5, 2021 | 04:18 PM
OneTinyFatGuy's Avatar
Thank you for this! I was looking to replace mine eventually as mine came in scuffed up a bit when I bought the car. Glad it is a simple pop off.
Radium
XE ( X760 )
Jul 28, 2024 10:29 AM
Apr 7, 2022 03:18 PM
dougndins
Jun 22, 2021 08:35 AM
2004XJ8
Feb 14, 2021 12:11 PM
retsel
XE ( X760 )
Sep 14, 2020 03:44 PM
