Remove second catalytic converter p300 euro 6b
Old Sep 12, 2023 | 01:11 PM
manuninja's Avatar
Default Remove second catalytic converter p300 euro 6b
I have an f-type 2.0L euro 6b and looking from underneath I have two barrels on the downpipe.
In particular, after the turbine, I have:
lambda sensor,
first barrel,
lambda sensor,
second barrel and then no other sensor after.
I was wondering, since I don't have any lamda sensor afterwards, can I eliminate the second barrel and put a straight tube? Has anyone done it?
i think is a second catalytic converter but i don’t know if i wrong.
to be clear, I would like to delete this one marked with an circle.
Old Sep 12, 2023 | 06:13 PM
OzXFR's Avatar
My guess is the second (circled) thingy is the OPF (Otto Particulate Filter) AKA GPF (Gasoline Particulate Filter).
Either that or the first thingy is the OPF and the circled thingy is the catalytic converter.
Either way removing it is likely illegal in your neck of the woods and if/when the car is tested for emissions or roadworthy or whatever equivalent you may have in Italy you will just be ordered to put it back on again under threat of a massive fine if "caught" again.
Old Sep 13, 2023 | 03:35 AM
manuninja's Avatar
Considering that mine is a euro 6b, registered in June 2018, it shouldn't have the OPF.
I understand that Jaguar installed the OPF on Euro 6D cars registered from 2019 onwards. The reason why I would like to remove it and replace it with a straight pipe or a 200 cell sports catalyst is to have a little more sound and lower temperatures.
When we put the car on the bridge, that circled barrel was a fiery red ball.
but i don’t know if i’ll have issue with this mod..
I don't worry so much about the controls, the first big barrel would remain.
The thing that makes me strange is that the two lambda sensor are before and after the first large barrel..
Old Sep 13, 2023 | 09:26 AM
Thunder Dump's Avatar
I know in the US, the 2.0L had resonators built into the downpipes to tune the sound of the exhaust. Those look a little big to be resonators but they could be.
Old Sep 14, 2023 | 02:05 PM
manuninja's Avatar
I don't think it's a resonator. I had the resonator on the central tube and I replaced it with a straight tube. the resonator in the center is empty while I believe this one is full inside.
Old Jun 13, 2024 | 12:12 AM
Nuno Miguel Monteiro's Avatar
Here are you located manoninja?
I've done it in my f-type p300.
Fell free to send me message by facebook
https://www.facebook.com/share/GVARc3DQtWWDKVbX/
Old Jun 13, 2024 | 12:31 AM
Forum delete my facebook link
use a downpipe
razagon is around 500€, there are on alliexpress for 300€, but shipping is 200, so more expensive..
https://jagmadness.com/index.php?rou...2&redirected=1
You will need a simple remap on ecu so the engine does not read the exhaust gases
Old Jun 13, 2024 | 05:52 AM
manuninja's Avatar
I got the ragazzon downpipe with sporty cat. I moved the second lambda probe a little further away and I don't have any errors in the ecu. the car runs fine
Old Jun 13, 2024 | 06:06 AM
Turko's Avatar
Default aftermarket exhaust.....
SuperSprint has the exhaust system for your car. Also, they are having a summer private sale taking place now.
https://www.supersprint.com/ww-en/sp...-facelift.aspx
Old Jun 13, 2024 | 08:38 AM
Manuninja
You buy the sport cat 200 cels ?
Did you notice diferenr sound?
The downpipe should dele the Two cats that came from factory.
Mine is 2017, but still have two cats like yours, betwen turbo and lower exhaust.
​​​​​​​Have you already mod the final mufler?
SteveHall
Aug 27, 2025 12:04 PM
Canadacat
Dec 10, 2019 01:27 PM
ddsand
Dec 16, 2016 10:38 PM
johnpreston84
Nov 13, 2012 09:35 AM
Walter1982
Apr 22, 2009 10:26 AM
