Request for Meridian system diagram
Old Apr 30, 2016 | 03:07 PM
jaguny's Avatar
Default Request for Meridian system diagram
Anyone with a Topix subscription that can post a diagram of 770 Meridian system? Looking for the components, speakers, wiring diagrams, etc. Thanks.
Old Apr 30, 2016 | 04:07 PM
xdave's Avatar
I've based these on the 2016 LHD model from your signature.
The wiring diagrams for 2016 MY are interactive so I would highly recommend subscribing for an hour and having a look at them yourself as you can link off to the connectors and component locations with ease. All the blue text in the PDF is clickable online.
Old Apr 30, 2016 | 04:28 PM
Smoke Em's Avatar
xdave,
You wouldn't happen to have the same for a 2016 S? I'm working on a complete overhaul of the system next Monday 5/9/16. If you do I would greatly appreciate it.
Thank you
Old Apr 30, 2016 | 04:55 PM
xdave's Avatar
Smoke Em, the information I can find on TOPIx is the same as above.
There are two different ICE systems fitted to 2016MY cars - the intouch pro (with or without the premium speakers) and the base. All the intouch pro cars are as above. The base will be different, but I cannot locate the wiring diagrams. Can you PM me your VIN and I will check I am looking at the correct range as there are three different manufacturing breaks in the 2016MY.
Old Apr 30, 2016 | 06:07 PM
xdave's Avatar
Thanks for the PM. I've attached the EWD for your VIN range based on the premium sound system option fitted.
Old Apr 30, 2016 | 06:14 PM
Smoke Em's Avatar
Thank you Dave
Old Apr 30, 2016 | 07:28 PM
DJS's Avatar
DJS
Great stuff, Dave. As I feared, it looks like the crossovers are integrated into the amp, which makes it trickier to just replace the speakers.
Old Apr 30, 2016 | 07:46 PM
Smoke Em's Avatar
Exactly. That's why I'm replacing everything. I'm replacing the speakers, the crossovers and amp. Can't wait, it's booked for next Monday and I will get it back Sat 5/14.
Old Apr 30, 2016 | 10:02 PM
jaguny's Avatar
@xdave, thanks much. This is very useful. In addition to comments on crossovers, I wonder if the amp is sufficiently isolated from the rear speakers.
Old May 1, 2016 | 09:23 AM
xdave's Avatar
If you mean physical isolation, rather than electrical, then unless the build process changed between 2015 and 2016 the amp in the coupes is bolted to a panel just forward and above the rear right wheel which has line of sight to the rear speakers on that side, and no insulation between it and the left hand speakers although not line of sight.
One benefit is that there is loads of space to mount what you want in there. Seriously - you could fit another trunk in the voids in this car. I imagine it would be a good car to crash into a lake with because the huge pockets of air would give good buoyancy while you make your escape.
I've only briefly looked at the schematics, but the amp appears to be a standard MOST amp only (i.e. it does not do other tasks) so it should be really easy to swap out with another that uses MOST or via a bridge + preamp. MB forums are the place to go if you ever want to do that yourself.
Old May 1, 2016 | 08:38 PM
jaguny's Avatar
Wouldn't you think L and R speakers would be physically isolated from each other and the amp?
Harry Dredge
May 1, 2016 07:23 PM
spartan2010
E type ( XK-E )
Apr 30, 2016 06:34 AM
brinny
Apr 30, 2016 01:56 AM
Boeingtravel95
Apr 28, 2016 05:36 PM
albjerryg
Apr 25, 2016 04:33 PM
