review on porterfield r4-s brake pads
Old May 16, 2018 | 07:08 PM
OzXFR's Avatar
Originally Posted by vettegood
with brake fluid change, what is the recommended fluid?
Any upgraded fluids from there? Street driving!
How much fluid should it take to change, any special method to changing fluid? pumps or special equipment needed, anything?
See this post and others around it: https://www.jaguarforums.com/forum/f...0/#post1865998
No special method or tools needed, these are fairly old-fashioned brakes that can be bled the old fashioned way, so either gravity bleed or pump using the brake pedal or use a powered pump like most shops do.
Old May 16, 2018 | 07:30 PM
andykreb's Avatar
ordered mine at LPI RACING,free shipping best price on porterfield r4-s pads...
Old May 16, 2018 | 09:24 PM
Unhingd's Avatar
DOT 4 SL.6 is specified and perfect for the application. My 3 year service is coming up in July so the fluid will be changed then. Since I'm not going to be cracking open the brake lines to do the rotor swap, there's no need to do anything more than check the fluid level after the project is done.
Old May 16, 2018 | 09:48 PM
lizzardo's Avatar
That matches my current expectations. I do need to get a 9mm hex key, per another thread, but that's hardly a difficult thing. Local auto parts? Amazon? Snap-On? There's one out there with my name on it.
Old May 16, 2018 | 09:51 PM
Unhingd's Avatar
All of those plus NAPA auto parts, and ACE Hardware carries Craftman tools if you don't have a nearby Sears.
Old May 17, 2018 | 08:20 PM
lizzardo's Avatar
The internet has one on the way. Not sure whether the pads or the tool will arrive first, but I expect that both will be in hand before the rotors themselves.
Old May 18, 2018 | 04:28 AM
Unhingd's Avatar
Paul thinks he will ship tomorrow or early next week. Don't know if they're coming by slow boat of air freight.
Old May 18, 2018 | 07:48 PM
  #28
lizzardo's Avatar
Porterfields are in hand (on shelf, to be accurate). I needed a few bits from Snap-On, so added the (paid too much for) the 9mm driver, but it'll be matchy-matchy with most of my other hand tools.
Calling back to some previous posts I saw: Front pads are massive, and came in a plain box, held together by a rubber band.
Old May 18, 2018 | 08:17 PM
OzXFR's Avatar
Don't worry, the 9 mm driver is the only "special" tool you will need.
Just one tip - do all the caliper bolts up nice and tight so use a 1/2" socket driver not a piddly 3/8".
Old May 18, 2018 | 08:23 PM
  #30
lizzardo's Avatar
I don't usually resort to 1/2" drive until I get to lug nuts or major pieces. I've gone to 3/4" only for really serious ****. What's the torque spec?
Old May 18, 2018 | 08:37 PM
  #31
Unhingd's Avatar
Mine didn’t even have a rubber band.
Old May 18, 2018 | 08:47 PM
  #32
lizzardo's Avatar
They like me better.
Old May 18, 2018 | 08:58 PM
  #33
OzXFR's Avatar
Torque specs:
Caliper bracket (wot bolts to the hub): front and rear both 115 Nm / 85 ft/lb.
Front caliper bolts (the slide pins, wot you need the 9 mm driver for): 58 Nm / 43 ft/lb.
Rear caliper bolts (15 mm IIRC but could be 12, 13 or 14 mm): 35 Nm / 26 ft/lb.
derrickonline
Jun 5, 2020 08:48 PM
ShaunPA
Dec 3, 2018 02:00 PM
aladamson
Mar 10, 2009 07:36 AM
rajinder75
Oct 14, 2008 10:42 AM
Exterior
Apr 25, 2006 07:23 PM
