Seat heater operation?
Old May 21, 2018 | 08:41 PM
domino_z's Avatar
Default Seat heater operation?
Hi guys
Just had my drivers seat leather skin swapped over with a new oem skin, went to put the seat heater on and it wasn't working
As i was heading back to the trimmer thinking they may have left a plug loose, it came on
I know with some past cars i've owned, the seat heater will only work if the inside ambient temp is higher than outside (my car was ice cold as it was left inside non-heated garage with windows open), is this the case with the jag too?
Old May 21, 2018 | 09:33 PM
tzoid9's Avatar
"I know with some past cars I've owned, the seat heater will only work if the inside ambient temp is higher than outside".
This is an interesting comment for me. I've owned quite a few different makes and models of American, German and Japanese cars over the years...in fact, it's probably shameful! All were purchased new and all of these cars had heated, electric core, front seats. None of these cars had thermostats that didn't allow the seats to come on above a certain ambient temperature, inside or out. I am sure of this statement because every time my wife is in the car, she fires up the electric seat where she is sitting. Like the movie....Some Like It Hot!
My guess would be that the plug for the heated seats isn't connected properly after the seat was reinstalled (it's loose) or you have a short some place in the system that makes connection after being jiggled around after driving.
Old May 22, 2018 | 12:39 AM
domino_z's Avatar
i had a late model L322 supercharger range rover vogue and I swear I remember the seat heated working intermittently, that's why i thought it was a UK thing
edit: did more driving today and the heater element just isn’t getting as hot as passenger side when I start both at same time, something definitely up
i Would have thought it was just an on/off switch, but could there be a thermostat that needs to be reset?
Old May 22, 2018 | 03:54 AM
jaguny's Avatar
Mine operates any time I switch it on, cold, warm, or hot, inside or out.
Old May 22, 2018 | 04:18 AM
Even Jaguars with Heated/Cooled seats (like my XK) aren't linked to ambient or AC temperature. They all simply go to the selected setting.
The cushion and squab have separate heating elements linked though the harness.
(double click on the image to enlarge it)
It sounds like you have a poor connection but the cushion heating elements in particular are very easily damaged. A regular cause is from owners kneeling on them when cleaning the interior.
Old May 29, 2018 | 01:30 AM
domino_z's Avatar
yep seems i was off with the seat heater operation theory
after leaving the car for a good week while i was away, getting back in this morning the heater seems to have reverted to normal operation
i'll monitor it over next few weeks, hope it's not a fluke
Old May 29, 2018 | 05:01 PM
Paul_59's Avatar
Banned
Also when selecting seat heater by pressing left or right temperature dial there are two or three settings available.
Press as above then turn dial and it will increase or decrease seat heat setting, then thermostat in seat element will maintain selected seat temperature
Old May 29, 2018 | 05:43 PM
Unhingd's Avatar
+1. 3 settings: warm, real hot, f...ing hot.
Old May 29, 2018 | 08:13 PM
domino_z's Avatar
yep all 3 settings working normally this morning
3 is uncomfortably hot just like how i remember
though i did notice once i turned the seat heater off, then turned it back on, it actually didn't come back on, and the seat itself wasn't hot enough to trigger the thermostat, so either this is normal and i never noticed it, or i have a faulty thermostat
i turned the car off, then back on, and seat heater returned to normal operation again
before i put the seat back in the car, i spent some time steaming the new leather cover to get all the shipping wrinkles out of it, it did get wet enough for water to roll out the back of the seat, so maybe that process may have damaged something
jproctor2
Mar 25, 2015 08:49 AM
barrymk2
XJ40 ( XJ81 )
Feb 22, 2014 10:39 AM
bigdog
Jul 15, 2013 10:12 PM
ant17
Dec 18, 2011 07:50 AM
DeepSix
May 9, 2008 07:11 PM
