shift light
Old Apr 24, 2021 | 01:08 PM
santacruz11's Avatar
Default shift light
am in the market for a shift light anyone know of the best for an f type r ??
Old Apr 24, 2021 | 01:23 PM
Hell Cat's Avatar
https://www.realcarbontastic.com/jaguar
Only one I'm aware of, integrated into the steering wheel
Old Apr 28, 2021 | 10:14 AM
lpf4's Avatar
If you're driving in Sport/Manual mode, there's a shift light built into the gauge cluster. The ring around the gear indicator in the center inverts, so it's a black number on a white circle when you need to shift.
Old Apr 28, 2021 | 12:06 PM
scm's Avatar
scm
I've got a little green arrow that shows when the car thinks I should upshift ...
Old Apr 29, 2021 | 06:03 AM
Scheffi's Avatar
This is only to drive efficient in manual mode.
The shift-light is to drive fast in manual mode ;-)
Old Apr 29, 2021 | 11:12 AM
Clutch's Avatar
I've never observed the inversion of the gear number but will check again - likewise on a green arrow. Are these MY specific?
Old Apr 29, 2021 | 12:52 PM
lpf4's Avatar
Not sure. I have a 16 R vert. I have the white background gear number, but have never seen a green shift arrow. The gear number background turns white based on anticipated shift time, rather than RPM, so if you floor it in first it'll turn white around 4500-5000 RPM, but if you're easing on the throttle it'll wait until right near the rev limiter before turning colors. Basically it comes on just early enough to make sure you have time to react and shift, no sooner or later. I actually really like how they implemented it more than a standard RPM triggered shift light. Pairs with the ZF8 transmission tuning perfectly.
Old Apr 29, 2021 | 12:57 PM
scm's Avatar
scm
My green arrow shows at low revs if I'm pootling along - seems to follow the ZF's shifting logic of early upshifts unless you're driving with a heavy right foot (i.e. "properly"!). When I next get to use my car I'll try the white/black display to see if that applies to my MY.
Old Apr 29, 2021 | 01:11 PM
lizzardo's Avatar
I see the green arrow. I thought it was MT-specific, but perhaps manual mode for the AT will show it. It seems to indicate that for fuel economy, you should shift up. If I'm driving enthusiastically, I never see it.
Old Apr 29, 2021 | 02:02 PM
fuzzysquid's Avatar
I have an auto '16, I see the black and white shift indicator in manual mode.
Old Apr 29, 2021 | 04:11 PM
scm's Avatar
scm
Definitely shows in manual mode in my MY18 auto. Not sure it's for fuel economy, as if you floor it the green arrow goes out! As I mentioned earlier, it seems to mimic the ZF's shift patterns, early for gentle driving, redline when driving properly. .
Old Apr 29, 2021 | 05:15 PM
lizzardo's Avatar
Since all I have is manual mode, mine is active all the time. I looked in my owner's manual and saw no mention of it, but it did mention an amber shift light for automatics in manual mode. From observation, it comes on when the speed, load, and selected gear as such that a higher gear would be more economical. It never comes on when a higher gear would lug the engine at the current load, and it never comes on when the requested power (pedal is only a sensor relaying the request to the system) is above a certain point.
Old Apr 29, 2021 | 05:39 PM
scm's Avatar
scm
In my handbook it's mentioned in the Warning and Information Lamps section: "The gearshift indIcator lamp illuminates briefly at the recommended gear change point (up-shift)."
Old Apr 30, 2021 | 10:09 AM
Unhingd's Avatar
As I mentioned in the other thread, that’s what the tach is for. The only way to improve on that is to place a shift light on top of the instrument cluster (tacky).
jfranks
Dec 14, 2016 06:10 PM
lickahotskillet
May 25, 2016 02:16 PM
magicjuan17
Dec 15, 2013 11:46 PM
rdp
Nov 4, 2009 07:00 AM
