Smoking on Start up
Old Dec 3, 2024 | 09:56 AM
kansanbrit's Avatar
Originally Posted by Cwis
Agreed. Just spoke to the shop. Owner said he'd comp me for part of the head gasket job, he just wanted to rule everything else out before doing a big and expensive job.
Up to you of course but I would keep driving it until it got worse so you know for sure. It will be really expensive because you may as well change all the timing equipment, water pump, coolant pipes etc. etc. while the heads are off.
Old Dec 21, 2024 | 09:57 AM
Cwis's Avatar
Update.
Head gasket job is done! The car is passing the engine block test now (the liquid stayed blue!!). The amount of white smoke did reduce, but it's still shooting some puffs out on cold starts. I'm comparing with the other cars I have and none produce as much smoke as the F-type.
I'm not too sure what else it could be since there are still no codes/CEL. I threw some BG44K in the tank to clean things out. Haven't noticed much a difference, not yet at least.
Old Dec 21, 2024 | 10:31 AM
Valerie Stabenow's Avatar
Default Congrats!
Do realize that the Fs are Direct Injection, and as such, the typical engine cleaners will not get to all the areas that may need a cleaning. While the additive cleaners do help. the deep clean is a different process.
https://www.jaginfo.org/threads/fyi-...-works.113917/ especially post #4
Edward_Woodward
Apr 24, 2024 07:56 PM
AttyDallas
Dec 12, 2023 04:27 PM
xjfourty
Jan 15, 2018 05:44 PM
Nigel Adelaide
Jul 30, 2015 05:03 AM
DRoti
Oct 24, 2012 03:37 PM
