Spacers pics... on stock suspension
Old Mar 19, 2017 | 09:07 AM
domino_z's Avatar
Default Spacers pics... on stock suspension
Hi guys
Quite a few threads with spacers on lowered cars but I can't seem to find any pics on stock suspension
I think 15mm might be too aggressive on stock height but please post up what you're running
Old Mar 19, 2017 | 11:38 AM
F-typical's Avatar
I thought 15mm was pretty much the thinnest spacer that meant you wouldn't have to grind the ends off the wheel studs?
Old Mar 19, 2017 | 11:56 AM
SanDiegoJAG's Avatar
Depends which rim you have. I still had to grind about 2-3mm off of the smooth part to get gyrodynes to fit back on with the 15mm adapters
Old Mar 19, 2017 | 01:14 PM
Unhingd's Avatar
+1.
Old Mar 19, 2017 | 04:48 PM
akc70's Avatar
I threw caution to the wind and ordered the 15mm through Lenny. I have the carbon blade rims with 305's and I will let you know in two weeks when I get back from vacation.
Old Mar 19, 2017 | 04:57 PM
domino_z's Avatar
I have the ceramic option wheels and afaik fit fine and the back spokes are pocketed
are all the wheel options same offset?
Old Mar 19, 2017 | 07:42 PM
Canadairjet's Avatar
Just went and took some photos for you of MY16 V6S with 20" Blade wheels on 295's with 15mm spacers. Gives the car a more aggressive stance and fills in the wheel wells very nicely. Hope this helps. I've very happy with them.
Old Mar 19, 2017 | 08:28 PM
jaguny's Avatar
Those blade wheels with spacers make the cat on the IRR with black pack!
Old Mar 19, 2017 | 09:02 PM
domino_z's Avatar
thanks so much for the pics, exactly what i wanted to see
i think 10mm might suit me better, might have to get a set custom made
Old Mar 19, 2017 | 10:29 PM
OzXFR's Avatar
I have the same as Canadairjet, but on the rear only.
Looks much better than stock and went straight on with no mucking about or grinding of studs. Here's a pic:
Old Mar 20, 2017 | 01:40 AM
OzXFR's Avatar
Here's three more pics giving you a better idea of how they sit:
Old Mar 20, 2017 | 05:45 PM
supercat'dXKR's Avatar
if you're going to run spacers, lower the car too..otherwise it looks somewhat like a 4x4
Old Mar 20, 2017 | 06:10 PM
OzXFR's Avatar
I agree when it comes to looks, the (relatively) huge wheel arch gaps are the only thing that disappoints me about the look of my F-Type.
Part of me wants to lower the car, but a bigger part says "no", due to a number of down sides (terrible pun intended!):
Cost - not cheap here in Oz, and I would prefer to pay my local suspension specialist to fit them rather than DIY.
Comfort - the ride is already hard enough. Not harsh, just "hard", and I don't want it any harder. And that's without the dynamic suspension turned on.
Getting in and out of the car - it's already a struggle for me and SWMBO, any lower and it would be a real PITA.
Parking/clearance - it's already hard enough to see out of and around other vehicles, and it already scrapes on those annoying parking spot concrete stoppers. Any lower and I would have to avoid those things altogether otherwise I risk damage to the bumper bottom lip, and it's still tough to accurately judge where the front of the car is. Same issues with driveways where I am, I already have to tackle many of them at an angle and very slowly and carefully.
So adding it all up I've pretty much decided not to lower the car, and to put up with the 4x4 stance.
Old Mar 26, 2017 | 09:18 PM
domino_z's Avatar
yeh ***** to lowering the car and ruining the ride which imo is the perfect balance bw comfort and handling, i'm really impressed with the dampening - funnily enough i get out of my m3 competition and into the jag for a smoother ride to work
thanks for the pics guys, much appreciated, and as per my initial thoughts, 15mm is just a bit too much. 10mm for me would be ideal, but i can't get a DRM style in 10mm
so i ended up ordering a set of 5mm non-drm spacers from Lenny @ motorsport-tech in the custom sizing for f-type ceramics (that is 139mm OD)
i'll have to get them anodized black locally to blend with the hats and wheels, and will check the oe thread depth once i have the wheel off as to whether i can get away safely with 5mm less thread on deez nuts
Old Mar 27, 2017 | 03:03 PM
jfranks's Avatar
When ordering from Motorsport tech, what did you specify as the center bore of the wheel?
Old Mar 27, 2017 | 07:23 PM
Mahjik's Avatar
Email him directly:
motorsportjr@gmail.com
Just tell him you want to buy spacers for a F-Type and he'll do all the rest.
Old Mar 27, 2017 | 08:10 PM
Unhingd's Avatar
Originally Posted by Mahjik
Email him directly:
+1.
Old Mar 27, 2017 | 08:22 PM
domino_z's Avatar
ordered as follows
OD 139mm
Centre bore 63.4mm
Width 5mm
he knows the pcd for jag
Old Mar 30, 2017 | 06:19 PM
BigDuke's Avatar
Did most of you who installed spacers go with anodized black or just the regular billet finish?
Old Mar 30, 2017 | 06:40 PM
When I ordered mine I assumed they would be black as thats what the large group order was. I was a little disappointed when they came in the regular billet finished, but once installed you don't even notice unless you make an effort to go an look behind the wheel.
