Spark Plug Change - what does this mean?
Old May 3, 2021 | 11:19 PM
schuss's Avatar
Default Spark Plug Change - what does this mean?
Changed my spark plugs yesterday (using TheRock's helpful guide). Bought 4 different wrenches at the auto parts store trying to find something that would work better but it's really just a beast, not looking forward to the next time. Also I think I will order new coil pack retainer bolts for the next time as I don't think those little star heads will last more than a couple changes without stripping.
They all look pretty clean and normal, except for cylinder 2B. I have 42k miles btw on a 2014 V8 S.
Bad sealing ring, getting blow-by on the plug perhaps? New one went in easily and smoothly by hand like all the others. I've never felt or heard it miss or otherwise run unevenly.
Something concerning? Any theories?
Old May 3, 2021 | 11:21 PM
schuss's Avatar
This is what the rest looked like:
Old May 4, 2021 | 05:53 AM
JacksonvilleJag's Avatar
IMO, your plug looks fine, on the bottom side at least. It's what I'd expect at that mileage and doesn't appear to be not sealing. However, the top side shows water is sitting on top of the plug in the cavity causing the corrosion.
Old May 4, 2021 | 09:11 AM
schuss's Avatar
I wonder how water got in there? The coil packs have a pretty thorough set of rubber seals and they can't really back out with the retaining screw tight. Any wild theories?
Old May 4, 2021 | 10:13 AM
007XKR's Avatar
My wild theory: You have a coolant hose beginning to fail, allowing a small amount of coolant to accumulate around the plug. As the engine heats up, the coolant evaporates, leaving behind a corrosive (to steel) orange residue. I don't have an F-Type, but if I saw this on my X150, I'd be going through the cooling system with a fine-tooth comb.
Old May 4, 2021 | 11:07 AM
schuss's Avatar
Oh that's an excellent theory. There are coolant hoses (with weird, snap-latch plastic fittings) right above this cylinder. Marked at #2 in the TheRock's doc:
Old May 4, 2021 | 02:07 PM
DJS's Avatar
DJS
I see a small amount of weepage around the SC/intercooler gasket - I’d check that too. My car, after 69k miles...
Old May 4, 2021 | 02:32 PM
schuss's Avatar
Lovely. Will do, thank you!
Old May 5, 2021 | 04:23 AM
Having a 2014, your coolant hoses and pipes are due to be replaced. Most notably the y pipe.
Old May 5, 2021 | 10:58 AM
schuss's Avatar
Interesting.
That's apparently a known issue? Is there a TSB or some guide on what that entails? Has anyone done it themselves?
Old May 5, 2021 | 11:07 AM
scm's Avatar
scm
Try https://www.jaguarforums.com/forum/f...2/#post2371612
Old May 6, 2021 | 06:17 AM
Originally Posted by schuss
Interesting.
Yes, yes, and yes.
https://www.jaguarforums.com/forum/f...placed-197383/
https://www.jaguarforums.com/forum/f...emoval-240307/
Hyrum Lindquist
23
Sep 24, 2020 07:36 AM
JX350
Nov 6, 2018 09:53 AM
v1rok
Sep 9, 2017 09:49 PM
mhamilton
Jun 12, 2016 08:28 AM
jag79
67
Mar 30, 2011 09:24 AM
