Steering wheel won’t unlock
Old Jul 30, 2019 | 08:06 PM
map1989's Avatar
Default Steering wheel won’t unlock
Hi folks, I currently have a 2017 Jaguar F-Type, I had a front end accident a week ago, now car steering wheel won’t move for anything, it starts, but looks like steering wheel stayed locked, is there anything that could of possibly broke in the front or would a sensor cause this failure, it only have 21K miles on it, it is a 3.0L supercharged, base model, rwd, please any help would be appreciate it, thanks in advance!.
Old Jul 30, 2019 | 08:21 PM
Unhingd's Avatar
How serious was the front end damage. Perhaps something is interfering with the steering linkage. I don’t have a steering lock on my F-Type.
Old Jul 30, 2019 | 08:24 PM
map1989's Avatar
It was bad, but right by passenger side, radiator is bad headlight is gone, front bumper and hood are bad as well, you think that would be?
Old Jul 30, 2019 | 08:41 PM
OzXFR's Avatar
I reckon you have one Lance, AFAIK all F-Types have one.
Easy to test - switch the car off, put it in neutral, then turn the steering wheel.
I bet if you try this it will lock after about 1/8 of a turn and you won't be able to unlock it unless or until you start the car.
Old Jul 30, 2019 | 08:49 PM
map1989's Avatar
Could the locked steering wheel be cause by an ABS sensor , speed sensor malfunction?
Old Jul 30, 2019 | 09:27 PM
Unhingd's Avatar
Nope. With car unlocked and fob nowhere near, I can turn full both ways with no locking. Never locked from day one. Thought that was the way it was designed.
Old Jul 30, 2019 | 10:19 PM
OzXFR's Avatar
Hmm, definitely doesn't work that way on mine.
I can't turn the wheel with the front tyres on the ground under full weight as the tyre grip is too much.
But if I raise the front tyres off the ground I need to turn the ignition on to fully turn the wheels either way otherwise the steering locks after about 1/8 of a turn.
I know this for sure coz many a time I have raised the front to remove the under tray, went to turn the wheel to access the two screws in the front of the wheel well without having first turned the ignition on and bingo, locked steering wheel!
Maybe it's a manual vs auto thing?
Old Jul 31, 2019 | 01:06 AM
stmcknig's Avatar
I don't know if steering lock went away with the "insert key here" stuff - will have to check mine.
Old Jul 31, 2019 | 06:25 AM
Unhingd's Avatar
No clue. I’ll see if I can find anything in the documentation. With some grunt, I can turn the steering wheel when the car is on a smooth concrete floor without having to take weight off the front wheels.
Old Jul 31, 2019 | 11:33 PM
map1989's Avatar
So I checked my steering linkage and looks like is free, nothing on the way, I was for a few things, that maybe the key fob needs to be reprogram with the car even tho it starts, or that the computer might need to be reset since it was in an accident?, please help, any help is much appreciated it, the jag is just sitting in garage.... 😭
Old Aug 1, 2019 | 08:16 AM
Mahjik's Avatar
On most cars, when this happens, there is something damaged in the ignition/key reading system. Does this happen with both keys?
Old Aug 1, 2019 | 08:46 AM
Tp10XKR's Avatar
Deleted
carzaddict
Aug 24, 2016 03:35 PM
bobandgwen
Apr 12, 2010 08:22 AM
GregC
Jan 27, 2010 09:15 PM
mlmotorsport
Dec 14, 2009 07:57 PM
sacrider
Dec 4, 2009 10:59 AM
