Stock Entertainment system update
Old May 21, 2025 | 12:30 PM
Doug5.0's Avatar
Default Stock Entertainment system update
Tried search, so sorry in advance if covered. I've had the Audio/Video button on the main screen go gray on and off for some time now. An internet search came with lots of folks experiencing it, but I never did see anyone get any resolution. Well I thought I'd try removing the carplay unit, which had been giving me fits of its own, and even in stock form, the AV worked one day, but alas, not the next. So finally my question: Has anyone ever gotten an "entertainment system ONLY" update, that didn't involve the whole system? (i.e. kept your burps and burbles.....) Thanks!
Old Jun 2, 2025 | 12:28 PM
Doug5.0's Avatar
bump?
Old Jun 3, 2025 | 08:12 AM
JagCode3's Avatar
What year is your car (Bosch vs Harman vs 2019+)? Can you run an OBD2 scan for error codes relating to the AV system? A picture of what you are referring to may help. How was your Carplay unit wired?
Old Jun 4, 2025 | 10:37 AM
Doug5.0's Avatar
Thanks. Its a '15 with the bosch system. I scan at an indy with a much better tool that I have, showed no errors. The car play was one of the IDcore variety, but has been completely removed. See pic. The AV button is grayed out, and most of the head unit does nothing. Selecting Nav or phone, (while still white and selectable) does nothing. Thanks!
Old Jun 4, 2025 | 11:06 AM
JagCode3's Avatar
That is bizarre.
Before digging into the wiring to check connectors, I would do a hard reset by disconnecting the battery at the negative terminal for a couple of minutes then reconnect. See if that brings it back.
Old Jun 4, 2025 | 01:20 PM
DJS's Avatar
DJS
Well, it’s in Valet mode. I don’t what’s limited in that mode, but I’d figure out how to turn off Valet mode first!
Old Jun 4, 2025 | 01:29 PM
Doug5.0's Avatar
That is bizarre.
Thanks. I should have given more background. I had done that several times, and even purchased a new primary AND secondary battery. That's why I'm at the "can I get a dealer reset" question. Thanks!
Old Jun 4, 2025 | 01:30 PM
Doug5.0's Avatar
thanks, but actually, that button is always there, in order for you to put it INTO valet mode. Not in valet mode currently.... Thanks!
Old Jun 4, 2025 | 01:54 PM
DJS's Avatar
DJS
Interesting, mine has never shown that.
Old Jun 4, 2025 | 02:07 PM
Doug5.0's Avatar
Interesting back at ya.... I had to chatgpt it, but apparently it didn't come standard until 2017. On your '14 and my '15, it was only on certain "packages...." who knew!
Old Jun 4, 2025 | 03:10 PM
DJS's Avatar
DJS
The other possibility is I’m a moron. Just drove my car, and yup, mine’s said Valet for the past 12 years. 🙄
Old Jun 4, 2025 | 04:24 PM
JagCode3's Avatar
Could be the amp: https://www.jaguarforums.com/forum/f...eakers-275048/
Old Jul 8, 2025 | 07:45 PM
Doug5.0's Avatar
Thanks. You could be right. My biggest issue is, that's its intermittent. Happens "sometimes...." And its usually at start up. Meaning once the car starts, its either on or off, and its like russian roulette not knowing if it will be on or off the next time I get in..... Thanks!
Rondog
Sep 7, 2024 07:48 AM
dennis black
Apr 14, 2024 12:54 AM
Meanmugga
Oct 4, 2023 09:01 AM
martinjp76
Mar 3, 2020 05:52 AM
Jay_Davis
XF (X260)
Dec 24, 2016 12:33 PM
