Supercharger oil analysis
Old Jul 26, 2021 | 05:39 PM
SinF's Avatar
Default Supercharger oil analysis
I decided to preemptively replace plastic coolant pipes with updated (2017 and later) parts to minimize chance of catastrophic coolant leaks. Part of this procedure required supercharger removal. "While I am there" supercharger oil was removed and replaced with Scol Eaton Synthetic Supercharger Oil p/n 001-60550.
I sent virgin sample and one that came out of my supercharger (35,000km, some racing) to Blackstone for analysis. Their conclusion was that I could probably could go longer on change interval but "Insolubles are oxidized solids formed due to heat and
use, and they're high at 0.2%. They didn't cause any trouble we can see, and the oil change should've removed them."
Out of the bottle virgin oil:
Original fill supercharger oil at 35,000 kms with some racing (meaning, time spent at high rpms and high heat).
Old Jul 26, 2021 | 05:54 PM
SinF's Avatar
Regarding intake sludge - here how it looks with no catch can , but 6 mo oil changes with Castrol Edge Professional 0w-20:
About 50 hours of track in addition to 35,000 km on the engine.
Old Jul 26, 2021 | 06:53 PM
lizzardo's Avatar
First question: Did you get the oil directly from Eaton, or is there another source (understanding you're in a different country than I).
Tangential question: Do you have the part numbers of the coolant pipes? I should consider this same operation, especially given the summer heat we get around here.
Old Jul 26, 2021 | 07:55 PM
cstall's Avatar
Originally Posted by lizzardo
...Do you have the part numbers of the coolant pipes? ...
I bookmarked this a while back:
https://classicairheads.com/blog/202...-carousel-1560
step-by-step w/ part numbers.
Old Jul 26, 2021 | 08:57 PM
Obi's Avatar
Obi
Ebay, and other online stores. Otherwise equivalents are readily available... ac delco... Audi etc. They also use eaton superchargers
Old Jul 27, 2021 | 06:55 AM
SinF's Avatar
It was ordered directly, but in hindsight due to international shipping charges and delays I should have went with a different approach.
Old Jul 27, 2021 | 01:42 PM
Therock88's Avatar
Good info. Thanks for taking the time to post it here. 👌
DC
Old Jul 29, 2021 | 03:15 AM
takeapieandrun's Avatar
Thanks for the valuable data point. Looks like some moderate interval length is appropriate (perhaps 30k miles maximum?) but definitely NOT a lifetime fluid with that 'oxidized solids' buildup.
Old Aug 1, 2021 | 11:31 AM
George05's Avatar
And evaporation due to heat in engine , it is very easy to do this DIY on the V6s
Vee
Apr 28, 2023 12:42 PM
mbates50
Apr 25, 2013 08:00 PM
brgjag
Apr 14, 2011 09:47 PM
2002XK8Orlando
Sep 9, 2010 10:04 AM
