SVR Maelstrom wheels on R - spacers?
Old Dec 20, 2019 | 05:42 AM
bobpies's Avatar
Default SVR Maelstrom wheels on R - spacers?
Hi all - sorry for first post and it being a question ! but i've just joined the f type clan very recently, and i've secured a set of Maelstrom wheels
i couldn't find a definitive answer on search for what size spacers i should be running with the Maelstrom wheels on 305s at the rear on a 2015 R RWD
from my understanding the wheels sit tucked in a little further than stock (i'm currently running 15mm spacers on Tornado wheels) - i've been offered 20mm spacers with the wheels?
thanks
Old Dec 20, 2019 | 10:38 AM
Unhingd's Avatar
thanks
If you know the offset on the rear Maelstroms, I can tell you the max. safe adapter.
Old Dec 20, 2019 | 11:34 AM
bobpies's Avatar
from what i've read they are ET54 (20x11) on 305/30/20
Old Dec 20, 2019 | 12:16 PM
Unhingd's Avatar
If that's the case, OP could safely deploy 25mm adapters. The 20mm adapters will work well.
Old Dec 20, 2019 | 02:06 PM
bobpies's Avatar
thank you )
What would the difference be compared to how I have it now ? I’m running stock 20 tornados 10.5 on the rear with 15mm spacers
I wouldn’t want it any further in than it is at its currently sitting well
Old Dec 20, 2019 | 02:31 PM
Unhingd's Avatar
thank you )
You’d need 25 mm adapters to put them in the same place.
Old Dec 20, 2019 | 04:56 PM
bobpies's Avatar
thanks
would that mean 5 mm on the front if I’m currently running 15mm?
Old Dec 20, 2019 | 09:40 PM
Unhingd's Avatar
thanks
i need the front wheel width and offset to answer that.
Old Dec 21, 2019 | 04:01 AM
bobpies's Avatar
So I Just came across this post https://www.jaguarforums.com/forum/f...2/#post1914759
im a bit confused as Zsmoothg there appears to be running 10mm with anything wider rubbing.
Terrance39
Aug 22, 2021 01:50 PM
powerhouse
Jan 1, 2018 04:23 PM
frank james
Jul 19, 2017 02:59 PM
Loxmth
Jul 18, 2015 11:11 AM
srjag
Oct 31, 2009 11:11 AM
