Transmission output shaft play
Old Aug 24, 2025 | 04:11 PM
Adam Deermann's Avatar
Default Transmission output shaft play
Hi,
I still have a whine somewhere in the drivetrain. It is speed sensitive, above 50 km/hr. It is a slow hum. I have replaced the rear bearings and diff. That made a lot of difference, but not there yet.
I found some play at the centre driveshaft bearing, the wheels are not yet aligned, one front disk is slightly warped. But I also found play at the output shaft of the transmission, no leakage. Is this normal?
I have a MY2014 base V6. 90k kilometers.
is it a ZF 8HP? Of which type?
thank you,
Adam
Old Aug 24, 2025 | 05:40 PM
DJS's Avatar
DJS
The auto transmission is the 8HP70.
Old Sep 8, 2025 | 10:54 AM
Solved, it was the front wheel bearing
johnrmclean
E type ( XK-E )
May 30, 2025 08:38 AM
baxtor
Jan 21, 2018 05:19 AM
andrew lowe
Jan 17, 2016 12:05 PM
philb1984
Aug 20, 2014 03:28 AM
Harleychris1969
Jan 1, 2014 08:12 PM
