Transmission output shaft play
Hi,
I still have a whine somewhere in the drivetrain. It is speed sensitive, above 50 km/hr. It is a slow hum. I have replaced the rear bearings and diff. That made a lot of difference, but not there yet.
I found some play at the centre driveshaft bearing, the wheels are not yet aligned, one front disk is slightly warped. But I also found play at the output shaft of the transmission, no leakage. Is this normal?
I have a MY2014 base V6. 90k kilometers.
is it a ZF 8HP? Of which type?
thank you,
Adam
thank you,
Adam
johnrmclean
E type ( XK-E )
May 30, 2025 08:38 AM
