Tuning: Viezu Predator 670 bhp F-type
Old Nov 11, 2018 | 09:09 AM
John Jones's Avatar
Banned
I have both pulleys and catless downpipes. VAP had to pull some timing out of max rpm in the tune or itd go into limp from the coils not keeping up.
Old Nov 11, 2018 | 10:22 AM
Unhingd's Avatar
You have the dimensions correct. Just go with the lower pulley. Going with both will overdrive the SC which loses too much efficiency at the top end. The lower pulley alone (with the corresponding tune) will substantially improve low end torque.
Old Apr 28, 2019 | 03:49 AM
Chris starko's Avatar
Originally Posted by FType17
Those claims are quite lofty... With Project Vengenace 640 (V6) pretty much done at 0-60 in 3.0 seconds completed I moved on to the Incubus 700 (V8) and at 690Hp it does NOT turn 2.8 0-60 nor 10 seconds on the quarter....
To achieve that, it needs to shed another 200lbs or so. It's a nice "promotional" video. Powerwise it's comparable to Lister and they have higher numbers (0-60 in 3.2)
Are you AWD? You should be able to do 10.9 easy with 690 hp. In fact, math says that you should get a 10.89 at 14% drive train loss (you should get less) (or more with some 103 or 105 octane) and lastly, decent shoes are key, the key ingredient. Go wider if the tuner can compensate for slight front rear diameter variation, and stick with pilot super sports or pilit sport 4s. Go to 265,35,20 and 305, 30, 20. 10.8 would be in reach probably.
Viola, you not have a 10 second car and are banned from the track until you put a weight increasing cage in!
DublDwn
Nov 30, 2017 10:21 PM
zach05855
Aug 31, 2016 01:26 PM
gh27
Aug 19, 2016 11:56 AM
ImNotFamousAnymore
Apr 29, 2016 10:53 AM
mcr74
Jul 5, 2014 03:45 AM
