Unable to get garage door opener / F-Type R mirror button
Old Apr 23, 2022 | 03:38 PM
kb58's Avatar
Default Unable to get garage door opener / F-Type R mirror button
Read the owners manual (several times) and believe that I'm following the instructions exactly.
  1. Ignition on
  2. Press "Learn" on garage opener motor
  3. Within 30 seconds, press and hold one of the opener buttons on the rear view mirror for 2 seconds, and release.
  4. Repeat Step 3 three times.
Doesn't work. The light blinks fast, then goes steady, as if it's picking up the codes, but after the process, the door will not open.
Searched on this forum and turned up nothing other than HomeLink issues. I politely request the hive to point out my dumbness, as apparently I'm the only one on earth to have this issue. Oh, and I tried it with the engine running, no change, and also tried shutting off the car after programming, thinking that maybe it would work during the next ignition-on cycle. Nope. Before and after this, the handheld remote continues to work fine, so there's no issue there.
Old Apr 23, 2022 | 04:44 PM
Unhingd's Avatar
The garage opener button on the mirror doesn’t react instantly like all other openers. After you think you’ve programmed it, try opening/closing the garage door by holding the button for 2 seconds. (Took me awhile to figure this one out).
The other possibility is that you have a new technology receiver in your door motor that doesn’t recognize the jag signal. There are repeaters that can resolve that issue. Others that have dealt with that issue will be able to assist.
Old Apr 23, 2022 | 05:11 PM
Carbuff2's Avatar
I know that we did a LOT of ladder climbing to get our opener to work.
Our friend BRITCAR had to call in his garage door company to get his to work with the car.
Old Apr 23, 2022 | 05:32 PM
kb58's Avatar
Thanks guys, I'll try holding the button down longer, fingers crossed.
Old Apr 23, 2022 | 08:11 PM
SouthSider's Avatar
I always have a problem programming a Homelink following the directions in the manufacturer's manual. I eventually go to the Homelink website and follow their directions.
Old Apr 23, 2022 | 08:24 PM
kb58's Avatar
I don't think that this is a Homelink thing. It's an ordinary garage door opener purchased 13 years ago, long before the whole home networking thing took off. All it has is a code-rolling system. Checked the manual and it's of no help, doesn't mention HomeLink, and basically says the same as the Jaguar manual when programming a remote. I may be stuck having to either carry a physical remote control, or buying a new unit, possibly ending up in the club where "the Jag system doesn't 'just work' with Homelink", hah.
Old Apr 24, 2022 | 12:09 AM
bjg625's Avatar
When I replaced my opener a few years ago it wouldn't program to the car. When I called open company they asked for my vin and new of problem immediately they sent me a bridge that solved the problem. Not expensive to purchase but got one free..
Old Apr 24, 2022 | 12:27 AM
kb58's Avatar
Hmm, okay, maybe I'll give that a try. Problem is that since it's 13 years old, I expect to hear great laughter about what I can do to correct it...
Old Apr 24, 2022 | 09:17 AM
Jay_Davis's Avatar
Yes, the instructions in the manual for my 2018 were not correct. The instructions I found on the Homelink website worked. Note that on the Homelink site they have instructions for various versions of it, but it didn't take too long to figure out which one applied to this car.
Old Apr 24, 2022 | 10:16 AM
kb58's Avatar
I checked out the HomeLink YT video,
I'll try again, as I had not cleared any preexisting codes from the car, maybe that's it.
Thanks again, guys.
Old Apr 24, 2022 | 10:21 AM
lizzardo's Avatar
I can't remember the incantation I used to get it working, but I do recall that it took a number of attempts before I got action. One thing I don't see in the procedure you describe is teaching the transmitter in the mirror from your original opener. I've got a split door and have button 1 operate one side and 2, the other. I needed to program each button from my remote before having each opener learn.
Old Apr 24, 2022 | 11:35 AM
kb58's Avatar
If you're referring to my post, I did try that way first, but it failed as described in the Jag owners manual, because it's a rolling code system. I then tried Jag's recommended method for that type system but it failed as well.
Old Apr 24, 2022 | 11:56 AM
lizzardo's Avatar
I have rolling codes, too. I wish I could better remember, but it's been years. I do remember that I had to both teach the mirror transmitter what the buttons should do and then teach the opener about the mirror transmitters.
Old Apr 24, 2022 | 12:42 PM
kb58's Avatar
Works now!
Using the above YT video (for my Chamberlain opener system), the only thing I did different this time was erasing preexisting codes. Of course, the first time I tried it after that, using the Learn button, didn't work, again. I tried pairing it using the garage remote control, which failed - again. The third and last try was to again try using the Learn button, and then it worked. So, yeah, there's some magic incantation that needs doing, and I found it by accident, so, like everyone else has learned, don't ask how to make it work first time. My best advice is to clear all preexisting codes and try pairing it more than once.
I guess I misunderstood what "HomeLink" is exactly. It's not a communications protocol, but a general reference to anything in the home controlled wirelessly? Thanks guys, I'd still be stuck without this forum!
Old Apr 24, 2022 | 02:49 PM
SouthSider's Avatar
Homelink is a company.
Old Apr 27, 2022 | 08:15 PM
tzoid9's Avatar
I feel the O/P's pain and agree with others who have fought this issue every time they get another car...whether it's a new car or used, you seem to always have this issue. The following method has worked well for me numerous times....I just bought a new Genesis GV70 and had to use this method to get the Homelink system working. In my opinion, it's the advent of the rolling codes that screws up the works. Anyway, try this one, fingers crossed....be sure you've cleared all the codes on your mirror buttons and be sure you are within 8-10 feet of the garage door opener motor, where the learn button is located..
1) get a hand help transmitter, put it right next to your rear view mirror buttons and simultaneously press both of those buttons (you may want to "break" the garage door chain from the automatic door opener, just for peace of mind).
2) then use your mirror homelink button to see if the door opens/shuts.
3) next, push the learn button in the door opener and jump back into the car and hit the rear mirror homelink button. you'll know if it took by the change in light flashing.
4) if that doesn't solve the problem, try this way, instead....omit step 2 and follow steps 1 and 3.
I must have dicked with this Genesis for 20 minutes and went no where and then tried my steps 1-3 and it has worked perfectly. Good luck!
Jbm417
Oct 14, 2021 09:01 AM
lrbrowns
Sep 11, 2019 08:59 PM
Brian XK8
Jul 6, 2016 06:36 AM
dennyhle
Jan 28, 2016 11:57 AM
ragman1171
Jul 25, 2015 04:24 AM
