using the key to open the door
Old Nov 8, 2025 | 08:04 AM
doxJag's Avatar
Default using the key to open the door
So, I finally decided to try the key to open the door in case the battery was dead, or the FOB went dead. It was hard to turn, but I finally got it done, but the alarm went off and I had to turn it off with the FOB. How can you stop the alarm without the FOB in hand?
Old Nov 8, 2025 | 08:25 AM
JagCode3's Avatar
Since you can't start the car with just the key, probably the only way is to pop the trunk open and undo the positive or negative cable to the battery. You will have to reset the windows if you have a convertible after the dust has settled...
Old Nov 8, 2025 | 08:45 AM
DJS's Avatar
DJS
Would you have the physical key without the fob, since it’s stored inside the fob? I think it’s intended to be used when the car’s battery is dead, or the key fob’s is.
Old Nov 8, 2025 | 08:48 AM
doxJag's Avatar
if the battery is dead, how do you open the trunk (2017 convertible)
Old Nov 8, 2025 | 09:02 AM
scm's Avatar
scm
Get in the car and pop the hood, then attach 12V to the underhood terminals. So long as the battery isn't actually faulty (or disconnected!) you should be able to open the trunk.
Old Nov 8, 2025 | 10:47 AM
Penfold.'s Avatar
From the 2021 iguide it says: To unlock, turn the key blade clockwise and release. The alarm sounds if the door is unlocked until the smart key is positioned correctly to disarm the alarm. The alarm also sounds if the unlock button is pressed on the smart key
I expect it would be the same in other years but I'm not sure what "positioned correctly" means
Old Nov 8, 2025 | 11:19 AM
DJS's Avatar
DJS
There’s a spot under the dash you can place it if the fob battery is dead, and it will then let you start the car.
Old Nov 9, 2025 | 12:33 PM
Carbuff2's Avatar
Yes, the seldom-used mechanical lock cylinder can become quite stiff...and it is possible that the inside 'mechanism' isn't engaged enough to deactivate the alarm.
We 'exercise' our mechanical lock once a year, and apply a graphite lubricant like Lock-Ease.
I exercise it in the garage however, and the car isn't locked.
XJR 308
Dec 4, 2016 12:23 PM
payroll416
16
Jan 28, 2015 11:07 PM
MrJagXJ
Sep 15, 2013 06:32 PM
ixj8it
Oct 29, 2012 01:42 PM
BOB7747
Apr 25, 2011 05:33 PM
