V6 Differences?
There were four levels of brakes in 2016:
CCB - can't remember the sizes
Super Performance - 380mm/376mm
High Performance - 380mm/325mm
Performance - 355mm/325mm
My recollection remains that Super Performance was tied to TVB. I'll see if I have any pictures from before the upgrade to two-piece rotors.
However, as I never had any complaints about how brakes work, so I never fiddled with them with the goal of replacing and hence did not measure what they actually are. It could be the case that 'red calipers' are 380mm/376mm option.
I love the DSC on this car.
It's prominent on the list of things tend to I gush about whenever someone asks me about my ride.
They were ceramic coated, the open wheel design offers easy access for cleaning to the entire caliper without removing the wheel, and the Porterfields pads don’t yield much dust.
But they will have the dynamic mode switch that opens the valves all the time?
“Switchable Active Exhaust” was an option on early FType S and above and you had to pay extra to have that button that keeps the valves open all the time. That switch is below the gear lever and next to the traction control button. If you did not opt for the switch that keeps the valves open all the time, then the valves open progressively the more gas you give it. If you put it in both Sport and Dynamic Mode, rev it to 4000 and lift off the throttle, you’ll still get those wonderful pops and crackles.
Base FTypes do not have Active Exhaust valves at all but has a nice sound of its own.
I know it’s confusing.
The dynamic mode switch is the toggle switch that puts the car either in normal, dynamic, or snow mode. Dynamic mode will hold your shifts longer, gives you better throttle button, and makes the exhaust sound more aggressive. It doesn’t keep the valves open all the time.
Can't speak for earlier years, but for at least MY18 the base I4 and V6 got Active Exhaust standard, but Switchable Active Exhaust was an option. V6S and up got Switchable Active Exhaust as standard.
Maybe this will help. It is for all models, and is 2019, but should give insight into various options and differences. Placed a PDF at the link below on my drive.
Good info regardless, and straight from JLR, so no guessing.
DC
2019 Order Guide Specs
DC
