Vacuum line, going to rear of engine bay
Old Apr 19, 2025 | 06:30 AM
Carbuff2's Avatar
Default Vacuum line, going to rear of engine bay
I haven't found an answer (or vacuum diagram) via SEARCH...so help me out.
2014 base F (built in 2013)
Currently mucking about with the symposer, and have a black plastic vacuum line that I can't find where to connect.
It comes from the rear (left side of the trans) and has a 'hook' shape on the end. No rubber end fitting. Crawled under the car and can't see where it goes, from under there. No exhaust valves, so it can't be for that.
Have SEARCHED several Topics regards removing the symposer with no success towards identification. Started to SEARCH the service manual but have not been successful, either.
This all came about because I thought it would be good to change our supercharger oil. 20 minute job has become a nightmare after the tip of our syringe fell into the little fill hole!
<<SIGH>>
Old Apr 19, 2025 | 10:33 AM
f-driver's Avatar
it's the gearbox vent line coming up from the gearbox ending behind the symposer stuff.
Regards
Ulrich
Old Apr 19, 2025 | 10:47 AM
clubairth1's Avatar
Community Influencer
Correct and it's fooled a number of us including me! I thought it needed to be connected to something before it was explained to be a transmission vent. I also have never found any mention of this in any Jaguar publication.
Here is mine (2014 XJR) and I asked the same question. The tube usually has 2 dabs of paint on it. I have seen yellow and blue so far.
Old Apr 19, 2025 | 10:49 AM
Carbuff2's Avatar
Thx, my 'helper' said that the line was attached on the left side of the engine.
I'll look again when the effect of the Adult Beverages wears off!
Old Apr 19, 2025 | 10:54 AM
clubairth1's Avatar
Mine just disappears back under the transmission tunnel and I could not see anything more. I was interested to try and find it but even on the lift I can't find where it goes on the transmission yet. It was located pretty much dead center in the engine compartment.
Old Apr 19, 2025 | 10:58 AM
Carbuff2's Avatar
Yep, I'll be looking for the ENGINE side if there is a connection of any kind.
Old Apr 20, 2025 | 07:36 AM
clubairth1's Avatar
There is no engine side connection.
Old Apr 23, 2025 | 06:07 AM
Superfast0815's Avatar
Hi All,
that is the vent line for the Gearbox, see picture.
Reg. Hendrik
Old Apr 23, 2025 | 08:51 AM
clubairth1's Avatar
Thank you Hendrik! I have been looking for the diagram as I had not been able to find any mention of the vent. Probably did not look hard enough!
So a bit more background as this was a new item to me. Previously on the 6 speed ZF they vented the case back into the bell housing area rather than out to the atmosphere behind the engine.
So we never saw the vent unless you pulled the transmission.
The 8 speed version ran the end of the vent up to the back of the engine and added a 90 degree hook to the tube.
I wonder why the change?
Old Apr 23, 2025 | 08:54 AM
Carbuff2's Avatar
Hello all,
Thanks again, it is all back together. Runs fine, some residual spillage smells a bit, but it buttoned up fine. On our early '14, the securing clip fits to the rear of the wire harness support, just above the symposer. <Yes, I didn't take the pictures with the retaining clip fully inserted in the bracket>
To help future SEARCHers, here are some extra key words to help the question, for others in the future:
Transmission vent line
Rear of symposer
Hard black plastic with hook
Mystery line, open ended
Old Apr 23, 2025 | 10:49 AM
clubairth1's Avatar
Yes my 2014 XJR had that exact same clip.
Good looking metal rear water manifold!
pmaniuos
Apr 25, 2024 09:29 PM
mouserider
Dec 18, 2022 04:12 PM
Obi
Sep 7, 2021 07:58 AM
Chris Bonner
Sep 12, 2019 04:00 AM
