VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
Old Dec 26, 2019 | 08:57 AM
  #861
Unhingd's Avatar
Originally Posted by Nznoonee
Just got back from the service highly disappointed
1) The VAP belt appeared to be 100% the same as my OEM belt - two sided, 1348 length
2) The technicians said that there will be no space (or very little) for the belt between new lower VAP pulley and idler pulley. But anyway the belt from VAP is too short to put.
So they put everything back as it was and let me go home crushed and crying.
Attached the photo with idler pulley (red arrow) with lower pulley removed. Everything is stock
How could that happen? What do I do now?
From what angle did you take that photo? I don’t recognize that view. You’ll never be able to eyeball the difference between the two belt sizes. You can use some string to measure the difference. What model year do you have? Perhaps the SC belt routing has been changed.
Old Dec 26, 2019 | 09:03 AM
  #862
Nznoonee's Avatar
The photo was made from underneath. To the right of the arrow is the place where lower pulley should be.
I placed two belts nearby- they have the same letters on them, btw belt size is also written there. And yeah, I measured the size.
My F-Type is 2017 V6S
Also, why do Eurotoys offer idler pulley in their kit? I think it makes sense in my case.
P.S. Added some explaining marks
Old Dec 26, 2019 | 01:07 PM
  #863
Unhingd's Avatar
I had the original Eurotoys offering. The additional pulley that they were offering was not the idler pulley, but rather the tensioner pulley. It was the exact same size as the OEM pulley except it was smooth so that a one sided belt could be run. At the time, a two-sided belt was not available in the right size. Subsequently, eurotoys was able to provide a DK080568 double sided belt, and with that I reverted back to the OEM double sided tensioner pulley.
With the new lower pulley installed, you will still be able to slip a belt between that belt and the idler to install it.
Old Dec 26, 2019 | 03:58 PM
  #864
Nznoonee's Avatar
Thanks, now it's more understandable about the Eurotoys pulley, I also checked DK080568 length, and it is only 1cm bigger than the OEM, not sure it's this critical difference that is needed for the VAP pulley. I think I need an official comment on this from VAP guys.
Could it maybe be that the tensioner needs to be unscrewed and then put back only after the belt is placed? Ok, but why would I need the same belt anyways if it matches the current one..
Old Dec 26, 2019 | 11:12 PM
  #865
Stuart@VelocityAP's Avatar
Sponsor
1) The VAP belt appeared to be 100% the same as my OEM belt - two sided, 1438 length (this is written on both belts)
Sorry to hear about your issues. I don't know enough from your username to be able to identify your order, or who you are. There are two belt lengths we supply. Sounds like you need the longer one and got the shorter one.
If you can reply to your order confirmation email and mention this I'm sure we can get you a replacement sent out ASAP.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Dec 26, 2019 | 11:14 PM
  #866
Sponsor
Folks,
When updating the car firmware with VAP box, do I need to use any extra battery?
Asking because the manual says "Connect vehicle to power source" like isn't it connected already to the battery lol?
OzXFR's words above:
The only caveat with installing the tune yourself is you need to have a fairly powerful battery tender hooked up - preferably at least 30 amps - during the process otherwise you risk bricking the ECU.
Not quite clear to me why the original car battery isn't enough...
It's important to have a stable and high enough battery voltage when flashing the car. A trickle charger is more than sufficient. Unstable or low voltage can cause problems with the flashing, so a trickle charger is an excellent precaution.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Dec 29, 2019 | 01:04 AM
  #867
Nznoonee's Avatar
Solved the problem via email with Stuart.
Thanks for such quick reaction!
Old Dec 29, 2019 | 01:38 PM
  #868
lizzardo's Avatar
What was the resolution? Did you need a different belt? I ask because I have mine in hand but have not installed it yet. Yours is a different year than mine as well. I'm curious because I'm always interested in ways to spare myself grief.
Old Dec 29, 2019 | 01:53 PM
  #869
Nznoonee's Avatar
Yes, a larger belt is needed, Stuart told me that it's not always possible to identify which size should fit.
So I was already sent a new belt..or it's about to be sent, I got an invoice. (yep, that quick)
Old Dec 29, 2019 | 03:41 PM
  #870
RGPV6S's Avatar
From my own experience and watching this thread and the belt/pulley install thread it seems V6S F-Types up to MY 2016 use the shorter belt and above 2016 use the longer one. I don't know about the V8 cars. Just my theory based on looking at stock SC replacement belt fitment guides for various year Jaguars and Land Rovers with SC V6 engines. It's puzzling to me why VAP hasn't sorted this out yet. I have asked what VIN/MY is a cut off for different length belts but VAP doesn't seen to have a direct answer.
Old Dec 29, 2019 | 05:02 PM
  #871
Cambo's Avatar
According to the current parts catalogue;
F-Type V6 up to VIN K22184 has a 1412mm supercharger drive belt
F-Type V6 from VIN K22185 has a 1438mm supercharger drive belt
There are also different idler pulleys and tensioners for those two VIN ranges as well.
K22185 was the start of the 2016MY
Old Dec 29, 2019 | 06:26 PM
  #872
Sponsor
We are sending the longer belt. If you're concerned, email us with your order number and VIN and we can double check.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Dec 29, 2019 | 06:29 PM
  #873
Sponsor
Hi RGPV6S,
We have sorted it out, and did so some time ago. We know which of our belts needs to be shipped based on VIN.
We had an internal error (now corrected) with shipping which has resulted in a few people getting the wrong belts, for which we have a apologized & sent out replacements wherever identified.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jan 16, 2020 | 02:43 PM
  #874
Taylorguy74's Avatar
Talking
So you running an awesome new year sale anytime soon for ECU tunes?
Old Jan 17, 2020 | 10:40 AM
  #875
Sponsor
Just the Black Friday/Cyber Monday sales for us, I'm afraid.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jan 21, 2020 | 03:14 PM
  #876
sonny2's Avatar
MY2014 V8S purchased 2nd hand as the 2nd owner in 2016 with 4700 miles on the odo. She now has 108,7xx miles on her. All regularly scheduled maintenance performed religiously & slightly more frequent oil changes than recommended (just because). Mechanically, she is very sound. Been wanting to get more power & just got off the phone with Stuart. We talked a bit & I think going with a tune will probably be ok even though she has so many miles on her. Just clicked "Place Order" & now can't wait to see what the tune will do!
Old Jan 21, 2020 | 06:07 PM
  #877
XJ8JR's Avatar
If the car has been taken care of, the high miles shouldn't be a problem. I'm at 115k miles and I've been running the tune for over a year now.
Old Feb 3, 2020 | 08:30 AM
  #878
Fed ex countdown - 1 day left for delivery of my tuner!
So from reading through this thread, I understand that you can code some items - eco start/stop toggle, RPM limit adjust, throttle sensitivity, exhaust pop/crackles, etc. I was looking to find some real world experiences with the tweaks. Anyone have some personal experiences with the set ups they could share? Trials/changes?
Old Feb 4, 2020 | 05:00 PM
  #879
Stohlen's Avatar
You can't code them; VAP can make you a tune with those changes. Typically you'll receive a tune with/without eco start/stop, but that's it unless you ask for other things specifically. I've had VAP tweak throttle sensitivity a couple times for me, and been very happy with the results.
Old Feb 4, 2020 | 06:11 PM
  #880
Unhingd's Avatar
+1.
