Washed car and got rough running w/ "injector circuit high" code
Old Mar 15, 2026 | 07:54 PM
Valerie Stabenow's Avatar
Default Remote may no longer be
It seems the continuation of Remote was based on Jaguars statement that they would continue 2G 3g so that the Remote apps would work. Well, 2/3 g ended in 2022, but my Remote continued to work. Door lock/unlock, headlight flash, horn sound, window control, vehicle location /tracking. That all ended mysteriously mid-December 2025. Still working on it. See the "Telematics battery" thread for All the details.
Old Mar 15, 2026 | 09:31 PM
dennis black's Avatar
You have to upgrade the tcu to the 4g tcu module and program, it with SDD, I now have a a 2017 xj
and I'll show you guys how to do it, or maybe make a video
Old Mar 16, 2026 | 01:07 AM
chaadster's Avatar
Y’all are talking about issues with Remote, but those don’t apply to me because I’m a MY19.5 and have the most recent telematics unit, right?
However, I do have to pay Jaguar for the connectivity to use Remote, is that right? The car right now says the services subscription is expired, so that’s one of the reasons I wanted to go to the dealer, to make sure it’s all sorted properly. I haven’t really worked with a pre-owned, web-enabled cars before, so it’s all a bit confusing for me.
First, though, I gotta get this “injector circuit high” thing sorted. In the morning I should know if the battery is properly charging; it is taking my 4 amp charger a long time to get the job done, which I think was exacerbated by the “OBD2 no-sleep” issue, now hopefully corrected with the battery ground strap pull.
Old Mar 16, 2026 | 08:35 AM
JagCode3's Avatar
@chaadster Check if the red hazard triangle is lit in your center console. You should be charged up in 12 hours with a 4 A charger. If not it suggests a concomitant electrical drain pulling from your charger.
Old Mar 16, 2026 | 10:46 AM
Default OMG yes.. video YES!
thank you so much for posting... I thought I was literally at the end of the line for getting my Jaguar Remote app to work. I believe this is what is in my 2017, built mid-late 2016 F coupe Manual Trans:
the only question I have is that I do NOT have SDD capability in my car... there are only 2 USB ports in the cubby.
Did you get your 4G unit from this SX outfit in China??
Attached Thumbnails Washed car and got rough running w/ "injector circuit high" code-telemmodule.jpg   Washed car and got rough running w/ "injector circuit high" code-portlayout.jpg   Washed car and got rough running w/ "injector circuit high" code-4g-tcu.jpg
Old Mar 16, 2026 | 12:13 PM
chaadster's Avatar
Update:
After pulling the battery ground strap for 30 seconds and reconnecting the charger, I let the car charge overnight and this morning, had the literal green light from the charger! I disconnected it and fired up the car. It started and ran fine. I then shut it down, plugged in my Kiwi3 OBD device and cleared the codes, the engine check MIL went out, and so I took the Kiwi3 out and pulled the battery ground strap for 30 seconds again. I then took it out for a 40 minute, mixed roads romp, and had no issues at all.
So, while I have no definitive explanation of what caused the "injector circuit high" faults, it seems resolved. Was it drying of wires or plugs? Was it low battery voltage? Given that I'd gotten the low battery warning on the infotainment at one point, that I probably had a "no sleep" condition from the PPI, and that it took quite awhile to fully charge the battery, I'm hoping it was just electrical gremlins caused by poor battery state of charge. Time will tell.
No lie, though: I'm a bit scared to wash the thing! I went and got some waterless wash when I was out today, haha! I'm probably gonna order some of that Maxl One crap that's been all over my Instagram feed, too, just to minimize the need for wet washing...at least until my confidence returns!
Thanks to everyone for the insights and tips. I was so freaked out initially; my mind went right to worst case scenarios, but the forum helped me to be calm and methodical, so I appreciate the help!
Old Mar 16, 2026 | 01:58 PM
Carbuff2's Avatar
Rather than use a pressure washer:
Rinse with a 'mist' of water, or just a low pressure, high volume stream of water....
OR
Stand 4 feet farther back with the pressure washer?
Old Mar 16, 2026 | 04:07 PM
  #28
DMeister's Avatar
Originally Posted by chaadster
Update:
There was a post on here recently about some product to cover the plugs or whatever to avoid the issue on these cars that have the vent placement issues.
Someone else posted some other less pretty but functional solution as well. You’d have to search.
Are you planning to actively cover them in some way? That way you can wash your car properly and be less concerned.
Old Mar 16, 2026 | 06:44 PM
WSHudds's Avatar
Glad you got it resolved! Enjoy your F-type!
Old Mar 16, 2026 | 07:46 PM
  #30
the only thing about the TCU it has to be VIRGIN not used they are encrypted to a original vin number, i learned the hard way, but it helped me understand how it works, many members on this forum i have done, and you get your remote engine start back and climate adjustment, from 2018 on up your good
Old Mar 16, 2026 | 08:17 PM
  #31
chaadster's Avatar
OR
I don't think the pressure washer had anything to do with it. Remember, correlation is not causation!
All indicators point to, as I said upthread, battery's low state of charge.
Old Mar 16, 2026 | 08:21 PM
  #32
chaadster's Avatar
No, no plans for extended engine coverage at this point, as everything I've seen points to battery low state of charge. I've been running around most of the day today in the car and, despite repeated start/stops, no issues.
Relatedly, the first time I drove it, I noticed the auto start/stop was inoperative, but today, post charge, the auto start/stop was working. That's another indicator of low state of charge, as I understand it.
Old Mar 16, 2026 | 08:23 PM
  #33
chaadster's Avatar
Thanks, @WSHudds ! I did all day today, and hope to enjoy it even more in the future!!
Old Mar 17, 2026 | 04:32 PM
  #34
scm's Avatar
scm
NRelatedly, the first time I drove it, I noticed the auto start/stop was inoperative, but today, post charge, the auto start/stop was working. That's another indicator of low state of charge, as I understand it.
Yep!
Old Mar 18, 2026 | 07:29 AM
  #35
jdsengineer's Avatar
Lately I was only driving mine once a week at most and it was a 10 min trip to the store. During one trip the radio sound quit, then got a notification collision notifications were inoperable. I put it on a batt. charger and no problems since then.
It is weird how a low batt. causing random electrical glitches, so now its on a charger all the time since I only drive it 2000 mi per year.
BTW, if the start stop annoys you, a simple delete is to unplug a little black plug in the trunk. There is a thread with pics on where to find the plug.
Old Mar 18, 2026 | 08:24 AM
  #36
chaadster's Avatar
Yeah, I guess these are hypersensitive in that regard. My daily driver is a '19 Alfa Romeo Giulia, and while it seems to be comparable to the F in terms of electronic gizmos, it's not nearly as sensitive. I had the battery go flat once, but it did so without any drama other than an occasional battery MIL on the dash. I put it on the charger overnight and haven't had any trouble in the year since. That's my main point of reference.
Oh, it does! Thanks for the heads-up; I've heard about the "black plug" hack in passing, but haven't looked into it yet, so I'll run look for the thread.
willtoliv
Sep 9, 2020 09:09 AM
Imanonamas
May 12, 2017 12:15 PM
Sir Arthur Streeb Greebling
Feb 9, 2015 12:46 PM
Rod Miller
Jan 19, 2015 08:21 PM
Toller
Apr 7, 2009 09:23 PM
