Wind Deflector removal '17 F Type S Convertible
Old Nov 23, 2020 | 10:20 PM
Sparky H's Avatar
Default Wind Deflector removal '17 F Type S Convertible
Can not figure out a way to clean the soft top rear interior glass. Have searched threads to little avail.
I ain't the smartest cowhand.
Old Nov 24, 2020 | 12:18 AM
DJS's Avatar
DJS
With the top down, remove the wind deflector (between the hoops.) Then put the roof up.
Even more fun is trying to vacuum the area back there.
Old Nov 24, 2020 | 01:55 AM
tkwesa's Avatar
The wind deflector is removed by pushing down on it and pushing the clips off the top at the same time, allowing it to slide up.
Old Nov 24, 2020 | 03:11 AM
I've changed your thread title from windscreen to Wind Deflector.
Old Nov 24, 2020 | 06:52 AM
Carbuff2's Avatar
Once you become a seasoned 'Vert owner, you can remove the wind screen with the top UP.
As the owners manual says, push down on the deflector's top support bar (within an inch or 25mmm of the side, so that you don't bend it). Then you can move the side support's clip towards you. Raise that bar an inch beyond the side support, then pull it towards the front of the car. The bottom will clear the side support eventually.
Replace in reverse order.
Old Nov 24, 2020 | 08:36 AM
Sparky H's Avatar
Default Windscreen remove
Thank you Sir....I was born and raised in Eastern Canada, should have figured that! Maintained citizenship as I worked the North Sea for many years.
GOD SAVE THE QUEEN!
Old Nov 24, 2020 | 08:38 AM
Sparky H's Avatar
EXCUSE PLS....WIND DEFLECTOR! My problem.....inadequate decompression.
Old Nov 24, 2020 | 09:41 AM
Dave Whitefield's Avatar
Don't worry about not knowing this... I had my 2017 convert for almost 3 years before I discovered this bit is removable. My brother and I took a 4,500 mile trip in it, really needing some extra storage space, but never figured out that removing this thing would give us the access to the well behind the seats. A couple of real dummies! Of course, you can't put the top down if you have stuff in the well, but hey, when you're going from point A to point B on the highways, it works well.
Old Nov 24, 2020 | 10:00 AM
Sparky H's Avatar
Thanks Dave....This Forum is soooo helpful. Perhaps several could meet in Vegas for a couple days of good runs thru the desert. Poker too!
Old Nov 24, 2020 | 07:33 PM
3 Speeds's Avatar
I purchased a plexiglass deflector off Amazon for $75 US and am very happy. Much better visibility out the back. But you need to put a strip of 1/4” stick on weatherstrip (any hardware store) under it or it rattles at speed. Once done, perfect and looks great too!
Dennis07
Aug 13, 2020 08:40 PM
Canadacat
Feb 17, 2020 06:52 AM
Spikepaga
Oct 24, 2019 11:02 PM
stetson1
Jan 1, 2015 04:05 PM
davideoandthebeast
Sep 30, 2014 06:20 AM
