Windshield wiper spray not working
Old Jun 25, 2018 | 10:39 PM
approx's Avatar
Default Windshield wiper spray not working
Anyone else have this issue? It was intermittant before, now it’s not working at all. I can’t hear a pump trying to run. No liquid but the wipers wipe.
I hate to spend another day driving back and forth to the dealer if it’s an easy fix I can do myself.
Old Jun 25, 2018 | 11:35 PM
OzXFR's Avatar
Check the obvious and easiest thing first - is your reservoir empty?
Old Jun 25, 2018 | 11:52 PM
approx's Avatar
I filled it when I first had the intermittent issues and it was nearly full. Double checked it again and it was still nearly full. Unless it’s somehow not making it to the front tank, I don’t think lack of fluid is the problem.
Old Jun 26, 2018 | 07:08 AM
Paul_59's Avatar
Banned
Never had the problem, interested in the cause and solutions.
As you're aware there are two reservoirs, main at rear, supplementary at front and two pumps, one pumps from rear tank to front tank and presumably a second pump to deliver to wipers and headlight washers.
I think low fluid level should trigger a warning light
Old Jun 26, 2018 | 09:34 AM
DJS's Avatar
DJS
Front tank and pump are behind the front right wheel arch, IIRC. You might check to see if any fluid is making it to the headlights, might help isolate the issue.
Headlight occurs when headlights are on, and after every 4th operation of the windshield washers, but not more often than every 10 minutes.
Old Jun 26, 2018 | 01:19 PM
frostysauce's Avatar
I'm actually also having this problem in my 15' R
Old Jun 26, 2018 | 04:37 PM
tzoid9's Avatar
You might want to also see if the washer ducts are plugged....it does happen!
Old Jun 26, 2018 | 09:44 PM
Neek's Avatar
My '16 FT-R is currently in service getting the 48k mile service, the windshield washer stopped working a few weeks ago. Pump died. getting it back tomorrow.
Old Jun 26, 2018 | 11:06 PM
approx's Avatar
No warning lights have been triggered... it'd be interesting to see if the front reservoir is filled at all though.
Good thought! Is the reservoir visible without taking anything apart? From above or below the car?
The washer ducts on the wipers themselves? I don't think that's the issue since they both stopped working at the same time, but... could be worth checking out!
Well, good to know I'm not the only one at least. I'll probably have it up there for the 16k service mark so I'll have them check it out then.
vettegood
Feb 11, 2025 07:15 AM
marvin.d.miller
Jan 24, 2015 01:49 PM
flyjag
Nov 12, 2012 01:49 PM
mzs_biteme
Jan 22, 2010 08:32 AM
