Amazing trick to find coolant leaks
Old Jan 29, 2014 | 08:58 PM
Gazoo2's Avatar
Default Amazing trick to find coolant leaks
Have you ever wondered why coolant is those funky colors, like yellow or green or orange? It's because they have fluorescent dye in them. If you are having trouble finding a leak, take a UV light (black light) and inspect your engine either in a dark garage or at night. You will immediately find where it has been leaking, even if it has dried off as the dye will leave visible streaks.
I bought a LED flashlight which transmits uv light that is intended to look for pet stains on carpet. It works fabulously for finding leaks from my big cat too.
Regards,
Old Jan 29, 2014 | 10:08 PM
plums's Avatar
interesting tip!
got a linky for the flashlight?
Old Jan 30, 2014 | 03:20 AM
Remarkable.
I was aware of a number of different fluorescent tracer dyes available for adding to a cooling system as an aid to leak detection but not that some manufacturers may be incorporating these in their standard coolant formulation.
Old Jan 30, 2014 | 08:28 PM
Gazoo2's Avatar
I believe I found the flashlight at the display rack for a rental carpet cleaner. Pet stores might have them too.
Old Jan 31, 2014 | 05:40 AM
Graham Royls's Avatar
Default Re UV light
Available from Amazon @$7.25
from LEDwholesalers #400nm
Old Apr 21, 2014 | 06:37 PM
Grio's Avatar
Default leak locating
I found at my O' Reilly parts store a special set of glasses and flashlight for seeing the fluorescing stuff I was supposed to put in my oil to find the leak. While this isn't what I got exactly you're supposed to use the glasses and have different additives to what ever leak ( water, oil, fuel, etc) that you are looking for. And I second the prior comment. do it in a dark garage as you can't see squat during the day.
Old Apr 22, 2014 | 02:13 AM
Originally Posted by Grio
I found at my O' Reilly parts store a special set of glasses and flashlight ..............
Welcome to the forum Grio,
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
ZJag
26
Sep 5, 2016 03:33 PM
sogood
Sep 15, 2015 07:35 AM
mcdutch
Sep 4, 2015 03:38 AM
Bcrary3
Sep 3, 2015 03:48 PM
OkieTim
Sep 2, 2015 12:48 PM
