Can used SRS nmodules be coded to new car
Old Jul 24, 2024 | 11:50 PM
tferrari's Avatar
Default Can used SRS nmodules be coded to different car
I have a 2017 Jaguar xe with a faulty SRS Module, (it was water damaged)
I tried before to program a used one and it did not work
I'd just like to check with any techs there if it is possible to recode used modules (program new vin etc) using sdd or Autel etc.
If not, I'll just stump up and buy a new module, used modules are $50 , new ones are close to $500 and above
thanks in advance
Old Jul 26, 2024 | 11:50 PM
Bill400's Avatar
What did you use in your attempt to program?
Did you try to reprogram existing as well as try reprogramming new?
Old Jul 26, 2024 | 11:58 PM
tferrari's Avatar
I used sdd. Old modue was water damaged.
Someone on facebook said i5 can me done with obdstar pt0.
That gadget costs about $550. Trying to confirm it will work as that is about cost of new airbag module.
If it works, I'd effective get a free tool out of the deal
Has anyone used this gadget on jaguar or even other sts modules please?
Old Jul 27, 2024 | 06:31 AM
Bill400's Avatar
JLR says that Pathfinder, not SDD is required for 2017 vehicles.
Consider purchasing a Pathfinder VCI and a couple of days of online access.
You can't program modules without access to vehicle data files, which were included with SDD V150 and earlier.
But that doesn't help you.
Online connection to JLR is required access the VDF.
Let us know how you resolve the problem.
Old Jul 27, 2024 | 07:25 AM
tferrari's Avatar
Default Pathfinder vs sdd
Thanks for the info. This vehicle came with no keys. Was water damaged. I programmed a used keyless go module, used body control module. Used telematics module, used seat module, and used modules from the center console, video module, the drive select module tgat pops up etc
the others have all been a breeze, I'm told the switch to pathfinder was mid 2017. My car is a little earlier, which is why I think sdd works. Just trying to avoid stumping up 500 for a single module. I'd rather pay a bit over that for tge right tool. At least that way I could do more in future,
Old Jul 27, 2024 | 08:22 AM
Bill400's Avatar
What version of SDD are you using? Where did you access the VDF?
Working on pre-2016 JLRs, VDF provided with V150 are sufficient.
V150.03 has nothing for X760.
If you have the required VDF and SDD works for you, try this:
With the original module installed, begin the reprogramming process.
Before committing (last step) substitute the new module.
This has worked on various Ford and JLR modules.
Old Jul 27, 2024 | 08:39 AM
tferrari's Avatar
Default Sdd
Darn, the original module was trashed, water damage
Cannot recall what I used, some kimd of clone sdd software i think
Old Jul 28, 2024 | 04:13 AM
Bill400's Avatar
OK. Understand that you are working with a Chinese hack.
Did you download the complete JLR vehicle data files for your vehicle?
Old Jul 28, 2024 | 10:05 AM
tferrari's Avatar
Yep, I've also coded many of the modules already including the BCM, keyless go, telematics and even 2 new keys as it came without any
panthera999
General Tech Help
Sep 5, 2024 02:01 PM
tferrari
XE ( X760 )
Mar 12, 2024 11:30 AM
citadeltcs
Dec 12, 2022 12:56 AM
citadeltcs
Oct 30, 2022 05:32 PM
Affy
General Tech Help
Oct 4, 2022 11:43 PM
