CCF changed via SDD, but nothing happens :)
Old Oct 21, 2020 | 05:22 PM
tmich's Avatar
Lightbulb CCF changed via SDD, but nothing happens :)
Hi,
I would like to do a couple of changes (e.g. vehicle max speed and radio frequency band and step adjusted). I found a SDD 160 with a "patch". Connected my car with it and started doing it. Entire process went well and smooth - logged with a golden key (engineering access), found parameters which I wanted to change, selected changes, approved them, uploaded/downloaded etc. Did a test drive and have not noticed expected changes. When I look into SDD -> Central Car Configuration it shows 9 critical mismatches (vs as build). Is that a reason why it does not work (changes did not affect car behavior) or there is another reason why it does not work?
PS. I also did a day lights reconfiguration (to Canadian setup) and it went flawless and works great - but it was a different procedure (not via CCF, but via a dedicated "wizard").
Couple of pictures below. Any suggestions welcomed and highly appreciated.
Old Oct 21, 2020 | 11:28 PM
Aarcuda's Avatar
Google search and read this document.
I just started reading it today and I know the answers in there
Old Oct 22, 2020 | 04:25 AM
tmich's Avatar
Hi, thanks for sharing. I've gone through a document. Looks like everything is okay (assuming car should use master CCF from RSJB). But still I feel like it uses "as-build" CCF...
Aarcuda
Apr 3, 2020 02:59 PM
sayitaintso
Jan 29, 2018 07:04 PM
K92
General Tech Help
Apr 23, 2016 03:07 AM
RaceDiagnostics
May 25, 2015 12:50 PM
Lagonia
Jan 12, 2014 07:26 AM
